Pages: [1]
Topic: Antenna Tuning Circuits (Edit on 17.Jan.25) (Read 1120 times)
LEO73
<Never a joy>
« on: 31. December 2024, 17:11:31 »
If the RF cable length is major of wavelength (λ) we can consider a 50 Ohm cable as a Network connections (inside there's more inductances and capacitors) |
| What is an Antenna tuning? It is a passive circuit made using Inductances and capacitors, this circuit permit to make the transceiver output load equal to the antenna load; in fact we would have the maximum power transfer (between transceiver and antenna) when the transceiver output capacitive-inductive reactance is equal to the antenna capacitive-inductive reactance.
EDIT 17.JAN.2025 (sorry for previous uncomplete versions) The manual says that the McHf transceiver works well with antennas that have an impedance of 50 Ohm. I deduce that in this case the output inductance of the transceiver is around 50 Ohm.
Usually: If Transheiver Load is major than Antenna load you need a High-Pass-L-Network-Tuning If Transheiver Load is minor than Antenna load you need a Low-Pass-L-Network-Tuning
Below there's an exercise that you can replicate for other frequencies:
NEVER A JOY
LEO73
<Never a joy>
Re:Antenna Tuning Circuits
« Reply #1 on: 08. January 2025, 15:41:14 »
Edit on 16-Jan.2024 (sorry for previous uncomplete versions) This is an opposite situation where Tranceiver Inledance in minor than Antenna Impedance, in this case we'll use a Low-Pass-L-Network Filter circuit. Below calculation values:
Never a Joy
Pages: [1]
