ve3ll
Power Off problem
« on: 05. May 2018, 21:28:55 »
I have problem with Power button on my RS-918. When I connect power connector to the radio Transceiver powered on without Power button. And when when I press power button to turn off the transceiver it does not power off. I have measured voltage on pin 2 of U3 (LM2941CT)/ when transceiver On voltage is 0.2 v, when I press Power button to off the transceiver voltage raise to 2.97 v. But transceiver does not power off. Need to remove power connector to turn off the transceiver. Can anybody to help me to solve this problem? Thanks.
« Last Edit: 05. May 2018, 21:30:52 by ve3ll » |
ve3ll
Re:Power Off problem
« Reply #3 on: 08. May 2018, 01:44:08 »
Yes, I have install latest software. Nothing change.
« Last Edit: 08. May 2018, 01:44:30 by ve3ll » |
