19. April 2025, 08:58:20
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: SWR Mod not done ERROR <- zurück vorwärts ->
   Author  Topic: SWR Mod not done ERROR  (Read 1720 times)
WD8BXS
« on: 10. July 2018, 23:52:19 »
On a new build I am having the SWR mod not done error, I have moved the T3 winding and have verified paths to MCU. Diodes check OK,  Still getting error.
Any ideas what else to look for??
Thanks,
Chuck WD8BXS
Thanks,
De WD8BXS vy 73
Re:SWR Mod not done ERROR
« Reply #1 on: 11. July 2018, 07:27:03 »
Hi Chuck,
take a look here
« Reply #2 on: 11. July 2018, 09:31:43 »
I think I remember we had such a discussion before in an older thread somewhere, but anyway: The SWR mod detection code measures certain voltage levels in the bridge. It seems in some cases the code wrongly detects the mod has been done, even without exchanged resistors due to measured voltages within the expected range.
But normally you also have to use different resistors, see Andreas link, it is not sufficient to just change the T3 connection. So if you replaced resistors and still getting this, check resistor values. If not, replace resistors.
« Last Edit: 11. July 2018, 20:37:09 by DB4PLE » Logged
WD8BXS
« Reply #3 on: 11. July 2018, 12:14:10 »
Thank yo so much for your replies, I will check it out tomorrow,
Thanks,
Chuck WD8BXS 73
Thanks,
De WD8BXS vy 73
