18. April 2025, 11:39:57
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: [solved]Another V6 service question <- zurück vorwärts ->
   Author  Topic: [solved]Another V6 service question  (Read 1792 times)
WD8BXS
« on: 20. November 2018, 00:03:58 »
just finished a V6 board set, all works well, but i am getting full output on 80/160 meters with no drive levels.
Receiving just fine, putting out a signal there as per my 7610 scope, no spurs.
Any ideas where to look for this bug??
Thanks,
Chuck
« Last Edit: 23. November 2018, 04:24:03 by DL8EBD » Logged
Thanks,
De WD8BXS vy 73
Re:Another V6 service question
« Reply #1 on: 20. November 2018, 11:20:32 »
Hi Chuck,
check bias voltage and current consumption change when going from SSB rx to  transmitting SSB without audio signal.
Have you tried to actively set the bias and does the current consumption change when changing bias?
If current changes, bias voltage is applied when transmitting as it should. However, it may be much higher than expected -> something around the bias ciruit is faulty or of wrong value and provides higher bias than expected.
If rx current is much higher than normal and does not change when going to tx, bias voltage is applied all the time, potentially a fault in he bias hardware.
WD8BXS
« Reply #2 on: 20. November 2018, 20:54:59 »
Yes that is true, but only on 80/160 meters.
works fine on all other bands.
I will do some voltage checks at a later date.
Thanks
Chuck
Thanks,
De WD8BXS vy 73
« Reply #3 on: 20. November 2018, 21:00:02 »
Hi Chuck,
yes, you're right. Can't be a general failure of the bias unit, otherwise it would occur on all bands.
« Reply #4 on: 21. November 2018, 04:46:14 »
Because there are no band specific behaviours in firmware the only possibility is that it changes because of self oscillating of the PA at those bands... Self oscillation can have the following reasons:
  • missing or bad rf blocking an BIAS , PA or driver circuit
  • badly working BPF or LPF on those bands (terribly mismatching)
  • T5 miswound or pkaced unhappily so that it is coupling to PA output transformers
Good luck
WD8BXS
« Reply #5 on: 22. November 2018, 21:24:43 »
I Installed the PTT relay and that fixed the issue.
I don't understand, but it worked.
Chuck
Thanks,
De WD8BXS vy 73
Re:[solved]Another V6 service question
« Reply #6 on: 23. November 2018, 14:52:18 »
That is the known issue (since ~2 years) about self oscillation when using pin diodes
WD8BXS
« Reply #7 on: 24. November 2018, 13:44:50 »
Yes, I thought that involved more than one band when that happened.
Chuck
Thanks,
De WD8BXS vy 73
« Reply #8 on: 24. November 2018, 14:04:51 »
Mostly it involves the lower bands < 14MHz. I cannot tell you what parameters are the ones which leads to self-oscillation - but with replacement of pin diodes with relay the issue is always gone.
