18. April 2025, 09:30:02
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: RTC Battery quickly discharged <- zurück vorwärts ->
   Author  Topic: RTC Battery quickly discharged  (Read 1756 times)
WD8BXS
« on: 26. December 2018, 13:50:59 »
How long is your battery lasting in your McHF?
Mine only lasted about 2 months.
Chuck
« Last Edit: 27. December 2018, 13:19:39 by DL8EBD » Logged
Thanks,
De WD8BXS vy 73
Re:RTC Battery
« Reply #1 on: 26. December 2018, 14:19:08 »
Mine is about 9 months under use and does have same voltage as brand new one.
But there is known issue with F7 processor that leads to too high current when there is no 4.4V power supplied. se take a measure of battery idle - it must be < 1uA when no 3.3V is supplied. The issue does not impact all STMs. There is a workaround (for F7/H7) which may work for F4, too.
WD8BXS
Re:RTC Battery
« Reply #2 on: 26. December 2018, 22:09:57 »
I am using the STM32F437VIT7 Processor.
There is no equivalent to C94 on the version 6 UI Board.
The NRST pin from the processor just goes to Pin 2 on the P8 header.
Should I put a capacitor with resistor in parallel top ground from this pin?
Chuck
Thanks,
De WD8BXS vy 73
WD8BXS
Re:RTC Battery
« Reply #3 on: 27. December 2018, 02:19:48 »
Would the dead battery cause the "Start RTC" selection in the debug menu to go away??
Chuck
« Last Edit: 27. December 2018, 02:29:15 by WD8BXS » Logged
Thanks,
De WD8BXS vy 73
Re:RTC Battery
« Reply #4 on: 27. December 2018, 07:12:29 »
Hi Chuck,
leaving NRST pin floating without resistor to Vcc and capacitor to GND is a hardware design issue. It is a wonder this works - no matter if RTC mod os present or not...
Dead battery leads to no identification of RTC mod.
Please follow the link Thomas provided - use google translate. I never have had done investigations on F4 MCU but it seems that F4 is also impacted as F7/H7.
Re:RTC Battery
« Reply #5 on: 27. December 2018, 11:35:33 »
re NRST: a check in the Reference Manual for STM32F4 RM0090, page 151 reveals that the NRST is internal pulled up to Vdd/Vdda aka Vcc. An external resistor is thus not necessary. There is also a schmitt trigger AND a filter internally, anything less than 20uS pulse will not trigger a reset. So in many cases, no external circuit is necessary. Having said that, long wires to pin 2 or other picked up signal in a transmitter may theoretically reset the processor and in this case a simple RC filter close to the pin may make sense.
In any case: grounding this pin will result in a permanently stopped processor. Energy efficient but not really useful state I'd say.
re RTC Start: Appears if rtc detection code thinks there is an battery connected. The way we do this is not the most reliable way, and it often appears to misdetect the presence. Why: We check if the backup ram remains powered between reboots by reading a value from this memory we wrote there earlier. This is normally only possible if there is an battery present which keeps the backup ram from loosing its contents. However, it appears that the mcHF UI keeps enough energy floating into the backup ram for quite some time after power down and thus our code can be fooled when powering on before the backup ram gets turned off.
Re:RTC Battery quickly discharged
« Reply #6 on: 28. December 2018, 10:42:11 »
möglicherweise würde ein Widerstand auch von direkt von 3.3 V nach GND ähnliche Wirkung entfalten. Im Prinzip sorgt der Widerstand ja lediglich für eine zügige Entladung des Kondensators und hält den Prozessor dann im Reset auch wenn noch etwas Vdd vorhanden ist.
Hier wird  https://community.st.com/s/question/0D50X00009XkgBTSAZ/vbat-current-draw-high-just-after-vdd-removed ein ähnliches Problem diskutiert. Könnte es sein, das auch bei unserem Fall der hohe Stromverbrauch nach einiger Zeit nach dem Ausschalten sinkt?
« Reply #7 on: 28. December 2018, 10:46:55 »
Hallo Danilo,
habe ich untersucht: bei uns bleibt der Stromverbrauch so lange hoch, bis die Batterie leer ist.
WD8BXS
« Reply #8 on: 28. December 2018, 18:14:35 »
So Andreas, are you saying that it is better to just forget about the RTC?
Chuck
Thanks,
De WD8BXS vy 73
« Reply #9 on: 28. December 2018, 18:41:28 »
No. For OVI40 we have investigated a workaround. NRST pin is sonected to a capacitor to GND and a "discharge resistor" of 47K...68K (board dependent) to GND. You can test following:
- Insert new battery
- set clock
- switch off mcHF
- test if Vcc pins of MCU do have voltage (>0.3V) even after few minutes
If so: F4 has same issue as F7 and H7. This voltage comes from battery and feeds MCU!!!
Now add a resistor from NRST to GND - start with 68K and decrease value until voltage disappears quickly. Now you have found correct value for parallel resistor.
WD8BXS
« Reply #10 on: 28. December 2018, 21:23:40 »
Will do!
I am waiting on a new battery  holder first.
de Chuck WD8BXS
Thanks,
De WD8BXS vy 73
