04. April 2025, 11:48:23
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Power output down, red (TX) light flashing <- zurück vorwärts ->
   Author  Topic: Power output down, red (TX) light flashing  (Read 1672 times)
S58J
« on: 24. September 2019, 06:45:53 »
Hi
Together with Marko, S54AM we are struggling to identify the erratic behaviour of his mcHF. They appeared suddenly after years of normal use, after latest FW upgrade.
The simptoms:
Power ON procedure - OK
Receiver - OK
Transmit - OK (with nominal power) for a couple of seconds than power goes down and RED (TX) LED is flashing maybe another 2 seconds after end of TX.
When restarting (Power OFF / ON) the simptoms start to repeat as listed above.
Any idea?
Kind regards
Janez, S58J
S58J
Re:Power output down, red (TX) light flashing
« Reply #1 on: 24. September 2019, 08:17:28 »
Hi Thomas
Thanks for your proposal. Before doing that I have to tell you that the same thing happens with dummy load (SWR 1:1.0) connected.
Kind regards
Janez, S58J
« Reply #2 on: 24. September 2019, 08:21:13 »
SWR detection is very poor. Additionally there is no way to match an outdoor antenna if output power is reduced at bad SWR. I do not see any sense in powering down at bad SWR so I never activated this setting. I am nearly sure you should do it, too.
S58J
« Reply #3 on: 24. September 2019, 11:35:22 »
Thank you Thomas, thank you Andreas.
Your proposal solved the problem! We can close this thread.
Marko, S54AM also send you both a big thank you.
Kind regards
Janez, S58J
