WD8BXS
Version 6.3 issue
« on: 02. December 2019, 14:31:41 »
Just finishing a ver 6.3
I have very low output on 20 meters. 10 mhz will give full output, but you have to drive it harder than usual. I have triple checked the LPF and bandpass filter, no success.
Does anyone have any ideas where to look next?
Thanks, Chuck
« Last Edit: 02. December 2019, 14:32:09 by WD8BXS » |
Thanks, De WD8BXS vy 73
WD8BXS
Re:Version 6.3 issue
« Reply #1 on: 02. December 2019, 15:54:13 »
Very nice answer, I will change them out and see. Thanks, Chuck
« Reply #2 on: 02. December 2019, 16:03:15 »
Hi
You used the wrong integrated circuits. You have probably installed CBT3253 and you should use CBT3253C
Good luck! Artur
« Last Edit: 02. December 2019, 16:03:36 by SP3OSJ » |
WD8BXS
« Reply #3 on: 02. December 2019, 22:34:25 »
Replaced both CBT3253C chips....No difference.
Chuck
OE3HKC
« Reply #4 on: 03. December 2019, 07:00:43 »
how is sensitivity of receiver part on 20m? if ok, perhaps menu tx settings (20m) are wrong.. 73
positron alter Hase
« Reply #5 on: 03. December 2019, 09:42:25 »
Hi, I would use oscilloscope, 14 MHz is not so high frequency. Just follow the path of the signal with oscilloscope probe using TUNE.
