02. April 2025, 23:57:24
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: CW with straight key <- zurück vorwärts ->
   Author  Topic: CW with straight key  (Read 1558 times)
WD8BXS
« on: 03. November 2021, 14:31:35 »
Hello all,
I had never tested the Mchf with a straight key before, but now realize it can't be done.
There seems to be some sort of delay (Stays keyed) when you push the key, it sends a several millisecond dah.
Now when I put the radio into SSB mode, you can use the PTT button on the mic and no delay, the PTT can act like a Str Key.
Is there somewhere in the software to eliminate the DAH effect?
TNX, Chuck de WD8BXS
Thanks,
De WD8BXS vy 73
Re:CW with straight key
« Reply #1 on: 03. November 2021, 15:37:49 »
Have you wired the key as mentioned in the mcHF schematics to the 3.5mm stereo plug?
WD8BXS
« Reply #2 on: 03. November 2021, 16:34:24 »
Hi Andreas,
Yes I have wired it as noted.
Chuck
Thanks,
De WD8BXS vy 73
WD8BXS
« Reply #3 on: 03. November 2021, 20:17:18 »
WOW, I just tried it again and now it is working!!!!
Must have been holding my mouth wrong!!
Chuck
Thanks,
De WD8BXS vy 73
