20. September 2026, 19:11:02
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: meter behaves strange on 20M <- zurück vorwärts ->
   Author  Topic: meter behaves strange on 20M  (Read 2584 times)
sm0nor
« on: 07. July 2022, 20:15:12 »
I have a 0.63 bought second hand. It looks well built but the meter behaves strangely on 20M. The power and the swr flickers up and down. SWR full scale and the power 2-3 watts up and down. On external meter it looks OK. The power moves a bit but the swr is stable. All other bands look ok.
Ideas?
Re:meter behaves strange on 20M
« Reply #1 on: 08. July 2022, 04:00:23 »
Check the levels using an oscilloscope at the SWR coipling bridge (input, output, fwd and rev). Depending on the results you have to go different directions.
sm0nor
« Reply #2 on: 08. July 2022, 19:38:01 »
OK. Unfortunately I don't have a scope. But I get where to look. I will inspect it and perhaps rewind it.
Thank you /Ulf
