19. April 2025, 18:22:44
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Verständnisfrage Old School S-Meter <- zurück vorwärts ->
   Author  Topic: Verständnisfrage Old School S-Meter  (Read 1681 times)
« on: 22. October 2017, 18:19:44 »
« Last Edit: 14. June 2024, 21:16:52 by DL8EBD » Logged
S53DZ
Re:Verständnisfrage Old School S-Meter
« Reply #1 on: 22. October 2017, 19:04:16 »
Thomas,
I think the "old school" S-meter shows the momentary logical OR function of RF input signal and the RF gain setting. So, if you set this over RF signal level you see only "RF gain" value. I think by saying this this S-meter mode is becoming more and more obsolete. The dBm display works really good.
73 Bojan
dg9bfc_sigi
I40-Mitglied
DG9BFC
« Reply #2 on: 27. October 2017, 16:31:24 »
wenn ich mich nicht irre war old scool s meter mit alter agc und neues s meter mit neuer (wdsp) agc
DD4WH
« Reply #3 on: 27. October 2017, 16:46:34 »
Hi all,
just dont use the "old school S-meter" any more, it used to produce problems and still does ;-).
Just use the S-meter setting based on dBm, its very accurate and easily understandable, because it does what an S-meter is supposed to do: measure the input signal level. (which the old school S-meter is not able to do) ;-)
I think by now we should just eliminate the old school S-meter from the software.
73 Frank
Teensy Convolution SDR
