IK5WWP
![*](YaBBImages/star.gif)
Re:CPU hot and no connection to PC
« Reply #16 on: 23. February 2018, 15:55:31 »
Update of 23/02/2018 Soldered a new MCU and tested the resistance between UI_3v_MCU and ground: about 1.3 Kohm (Ok, Before was only about 10 ohm) Note: any active and passive components between UI_3v_MCU and ground was previously removed: only the MCU. Now step by step I will re-put in place the components removed and every step I'll check the resistance. Just a few steps a day: I don't want to make another roast-MCU!
« Last Edit: 23. February 2018, 15:55:58 by IK5WWP » |
IK5WWP
« Reply #18 on: 24. February 2018, 13:35:28 »
The first thing I would test is if any short-circuits are between MCU pins which are side by side. You can take such very precise "peaks" like they are used at dentists. Connect them to a DVM in "short circuit test mode" and test all pins for shorts to their neigbours.
Thank you for this suggestion: before giving current I'll surely do also this test! 73, Lorenzo
IK5WWP
« Reply #20 on: 28. February 2018, 17:58:07 »
"Dentist test" done and passed ok. Now ahead step by step. A little step a time.
IK5WWP
« Reply #21 on: 03. March 2018, 10:53:46 »
Ok! Finally I have a working MCU. It is recognized by the pc and I can upload bootloader and firmware, but... Removed jumper on P6, removed the cable on DFU port, given +5V, I can only see a white screen. After a few seconds the screen light became not stable, but if I press and keep depressed the power on/off button the white screen become stable, so I believe it is a software problem and not an hardware problem. It's time to buy an ST-LINK?
IK5WWP
« Reply #23 on: 03. March 2018, 11:13:05 »
Hi Andreas! Thank you for your prompt answer. You sent me a populated LCD after the first expedition went to Portugal, do you remember? Have I to check something in particular on the LCD board?
IK5WWP
« Reply #25 on: 03. March 2018, 15:00:07 »
Disassembled LCD, checked all solder joint, cleaned accurately all the fluxant. Now the white screen is stable, the current absorption is about 70mA constant, but only white screen. No particular hot spot: checked with a thermal camera: max temperature about 25° C on the MCU and on the 3.3V regulator
What can I do now?
« Last Edit: 03. March 2018, 15:27:09 by IK5WWP » |
« Reply #26 on: 03. March 2018, 15:32:08 »
Ich hatte bei 2 neugebauten ui-Boards (V.04 und V.06) ein ähnliches Problem. Nach dem Flashen mit JP6 und dfuSe schien nach der Anzeige von dfuSe alles ok zu sein, aber nach dem Einschalten der Boards war der Bildschirm auch nur weiß. Abhilfe brachte ein 2. Flashen des Bootloaders, danach lief alles prima! Starte mal einen 2. Versuch !
73, Harri
IK5WWP
« Reply #27 on: 03. March 2018, 15:50:56 »
Attempted to upload bootloader and firmware almost 10 times: DfuSe ok, but the display is still white.
« Reply #29 on: 03. March 2018, 17:53:54 »
Attempted to upload bootloader and firmware almost 10 times: DfuSe ok, but the display is still white. |
| I had the same effect like DF5LI once. For me the solution was the same. After loading both .dfu files (bootloader and firmware) with dFuse i flashed again only the bootloader a second time. After that the board came up without any error.
If you have done all this, the only solution is to check all LCD connections from MCU to the LCD sockets with an ohm meter as Andreas wrote. In case all that does not help you then need to check the LCD on a running board where an LCD runs fine. Or...send it back to Andreas for a check
« Last Edit: 03. March 2018, 17:55:05 by peter_77 » |
