Re:Baubericht: UI mit 480MHz STM32H743ZIT6U
« Reply #17 on: 02. September 2020, 16:29:58 »
Old program? Thomas, what version of ST32-Link are you using?
« Reply #19 on: 02. September 2020, 17:18:55 »
The fault was the old program on the new one is OK thank you
« Reply #20 on: 03. September 2020, 08:18:42 »
Is it possible to block the STM32H743ZIT6U? I changed the settings: 1) Target / Option bites .... 2) Target / MCU Core ... I'm loading firmware, bootloader and firmware (it's OK) and TRX won't start.
I replaced the processor and now it's OK.
« Reply #21 on: 03. September 2020, 08:37:33 »
Because on the old program I could not upload the bootloader and I thought it was a setup problem (bites and MCU Core).
