Pages: 1 [2]
Topic: Problems UI with F7/H7 (Read 9844 times)
Re:Problems UI with F7/H7
« Reply #15 on: 08. March 2020, 10:37:38 »
Thats NOT normal. As you can read a page before in this thread. There is NO need for the ST-Link at all ! It all can be done with just the DFuse tool ! Make the P6 bridge, bring the board into DFU mode and flash the right bootloader. Bootloder files as well as firmware files are different for F7 or H7 CPUs ! Check the bootloader message if you like and after that flash the right firmware with the DFuse tool. Thats it ! Procedures can be seen here: https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=551;start=75 https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1055;start=0
The ST-Link tool is only needed if you (or testing) messed up the CPU registers. This can usually be seen when the board did not go into DFU mode anymore even with the bridge set on the UI. In that case you need to restore the registers (Andreas posted them the page before) to bring the board back into DFU mode. Then repeat the whole above procedure with the DFuse tool to flash bootloader and firmware.
« Last Edit: 08. March 2020, 10:55:47 by peter_77 » |
Macsim Gheorghe
« Reply #16 on: 09. March 2020, 20:43:54 »
Hello! I have done everything you advised me to, but the same thing keeps happening - the welcome message lights up, it stays like that, the LED is on, red. I have checked that everything works fine, but it doesn't go past the welcome message.
« Last Edit: 09. March 2020, 20:49:55 by Macsim Gheorghe » |
Macsim Gheorghe
« Reply #17 on: 09. March 2020, 20:54:52 »
Here's what it displays. Remains with this message and the red LED.
display.jpg « Last Edit: 10. March 2020, 08:50:54 by Macsim Gheorghe » |
« Reply #18 on: 14. July 2020, 19:29:43 »
Hi
All s OK I also have this problem. You need to load the bootloader and firmware again.
73 Artur
Pages: 1 [2]
