Re:[gelöst] Magnify Modes beim 480x320 LCD
« Reply #16 on: 30. January 2018, 11:52:22 »
I have 2.7.74 running on the 3.2" box as well. The only thing i haven't done so far on that UI is changing the bootloader to the latest and greatest but i guess this is without any influence on the above behaviour. I will now do it, just to be sure...
« Last Edit: 30. January 2018, 12:06:07 by peter_77 » |
« Reply #18 on: 30. January 2018, 12:00:23 »
What is strange... I just switched the box off with magnify left on 2 and then back on and...things work ! Now magnify 2 and above work without any error. Sounds funny but it looks like the old German "AEG" (Auschalten, Einschalten, Geht !) solved the issue. It is not reproducable anymore. Tried that 5 times. (Bootloader not updated so far)
« Last Edit: 30. January 2018, 12:01:33 by peter_77 » |
« Reply #20 on: 30. January 2018, 12:04:12 »
Yepp, same here. Weired ! But if we can fix it that way who cares ?
positron alter Hase
« Reply #21 on: 30. January 2018, 12:53:56 »
hmmm... have to play with it... Code is getting more complicated and there could be something we missed...
« Last Edit: 30. January 2018, 12:54:32 by SP9BSL » |
DD4WH
positron alter Hase
« Reply #22 on: 30. January 2018, 13:21:33 »
just a guess:
sd.magnify is uint8_t and old_magnify in UiSpectrum_UpdateSpectrumPixelParameters is uint16_t ?
and force_update will never become false in that function
But I may be totally on the wrong track . . .
73 Frank
