positron alter Hase
« Reply #285 on: 19. November 2017, 17:12:02 »
I can confirm that this problem doesn't occur on my mcHF. Yesterday all day long i had it on receive and changing to CW and SSB, but nothing happened. I have 3.5" lcd ofcourse and latest build.
« Reply #287 on: 19. November 2017, 23:20:54 »
Hallo Andreas Bis jetzt ist sowas hier auch noch nie aufgetreten. Das Gerät lief schon mehrere Stunden am Stück, meistens 20 oder 40m in SSB.
Gruss Reto
Re:letzte Betatestrunde ist gestartet/FW2.7.1
« Reply #288 on: 20. November 2017, 06:57:07 »
Hallo, die farbliche Unterscheidung der eingestellten Bandbreite im Scope-Betrieb finde ich Klasse. Danke vy 73 aus Erfurt Michael_K
positron alter Hase
« Reply #290 on: 20. November 2017, 16:30:15 »
Hi Thomas, you're welcome. I'm glad that you like it. It works better than my first one which i did in June. It was possible thanks to display code reworked by Danilo. Anyway I'm happy to be in this team!
Co
« Reply #291 on: 20. November 2017, 16:50:18 »
Re: Audio distortion
I had the set on all afternoon but could not detect any audio distortion.
After I connected the RF board to the OVI40 UI board the blue screen (button test)did not appear any more ! The reason might be that since power is now supplied by the RF board some delays are introduced by the power switching arrangement.
regards
Co
positron alter Hase
« Reply #294 on: 21. November 2017, 19:15:05 »
Hi, i had similar issue a year ago with WM8569. Two of 10 mounted on SMD line failed after 1 night of work (warm test before packing and sending to customer). It was definitelly not an ESD... Both pieces was hot when failed (only DAC issue, ADC was working ok). Unfortuntelly manufactured by Wolfson not Cirrus Logic...
« Reply #296 on: 22. November 2017, 11:40:19 »
Hallo zusammen ich habe da mal einen Frage werden mittlerweile schon die 3 Speicher ICS von der firmenware unterstützt da ich grade in den letzten Zügen bin das Bord fertig zu stellen denn Audio Verstärker kann ich ja direckt an die 12V Buchse hängen
« Reply #297 on: 22. November 2017, 11:57:08 »
@ANDY; Nach meinem Kenntnisstand wird nur der IC7 (1025, 1026 oder wie bei mir AT24CM02) unterstützt. Es erfolgt auch nur die Erkennung des IC7 in den Systeminfos Die anderen beiden sind für die Zukunft Michael_K
« Reply #298 on: 22. November 2017, 12:02:16 »
Hallo Andy,
Michael_K hat absolut recht: Derzeit gibt es keine aktuellen Pläne diese Speicher in der Firmware zu nutzen. Ob jemand in nächster Zeit mit einer Idee um die Ecke kommt, bei der so ein Speicher hilfreich ist, wissen wir natürlich nicht und dafür sind sie auch vorgesehen: für zukünftige Experimente/Funktionen (ohne zu wissen, welche das wann sind). Ist nur schwer, sowas nachträglich einzubauen, deswegen schon mal der Platz auf der Platine.
Co
« Reply #299 on: 22. November 2017, 15:56:18 »
On the OVI40 I replaced the LCD screen because touchscreen leads are damaged. I installed another lcd. But when I press power to start, the splash screen comes up briefly immediately followed by the blue button test screen. I can test the buttons with normal feedback on the putton pressed and touch screen coordinates and by a long press on the band- the set performs a reboot but only to repeat the same sequence : splash screen followed by button test. I can break the loop only by powering off with the power button. When I go back to the old lcd all behaves normally. I can't follow the logic. Would appreciate some advice.
Kind regards
Co
