03. July 2024, 10:22:32
Pages: 1 ... 19 20 [21] 22 23 ... 25 Go Down Print
   Author  Topic: letzte Betatestrunde ist gestartet  (Read 68278 times)
« Reply #300 on: 22. November 2017, 16:19:13 »
Hi Co,
on top of the button test there is an initial code. I think it is 20000 and that means "touchscreen press detected"...
« Reply #301 on: 22. November 2017, 16:25:14 »
Hi Co,
probably your touchscreen is bad, and reports "I am pressed". This leads to the keypress test screen.
See Wiki: https://github.com/df8oe/UHSDR/wiki/Firmware-FAQ#q-why-do-i-get-the-blue-screen-at-power-on
Co
« Reply #302 on: 22. November 2017, 16:55:18 »
Hello Danilo
Tnx for your reply. Sad, but what I do not understand is that the the touchscreen is operational because when touching the screen it comes back with the coordinates. So the TS interrupt is there and the registers are being read.
regards
Co
« Reply #303 on: 22. November 2017, 18:02:01 »
Coordinates and interrupt are independent...
Again: what is the initial code when you are in button test by accident?
Co
« Reply #304 on: 22. November 2017, 19:57:31 »
Andreas,
The code is 20000.
reagards
Co
« Reply #305 on: 23. November 2017, 05:04:25 »
That means that during startup a touchscreen event was detected.
I naver have had that - but there are some others who did have it, too...... Thomas, DL8EBD, can you please give some infor about that issue?
Co
« Reply #306 on: 23. November 2017, 07:34:45 »
Hi Andreas,
(btw: You are an early riser . I agree it is unsolicited interrupt. With a damaged TS you get the value 10000. I have the impression it is a timing error. I followed the discussion with Thomas on this issue but do not know of any final conclusion.
Of course I can force the active low TS-Int to a  high level to skip going into testmode but that renders the TS inactive.
regards
Co
« Reply #307 on: 23. November 2017, 07:47:34 »
Hi Co,
yes - sometimes I am an early riser. But I dont like this season where its getting light at 8 o clock or later - I am "light-driven"
I remeber there was a discussion and there was more than one OVI40 which shows button test - but my two never have had shown it by accident (5 LCDs here). So I am unable to participate in this discussion. I do not have any idea why this occurs at some OVI40 and LCDs and not at mine. So I do not know if the problem is located in LCDs or in firmware.
« Reply #308 on: 23. November 2017, 09:16:32 »
OK. Ist also noch ungelöst. Und bei mir nach wie vor niemals aufgetaucht bisher.
OK - unsolved yet. And again: I never have had seen this issue here.
« Reply #309 on: 23. November 2017, 09:29:26 »
Ich habe noch nicht mal meine Samples bekommen bis jetzt.
Roadmap:
  • am Tag, an dem ich die Samples bekomme, fädele ich mir einen Adapter und teste, ob das so klappt wie ich will
  • wenn ja, wird am nächsten Tag eine PCB geroutet und die PCBs in Auftrag gegeben
  • gleichzeitig bestelle ich einen Batch LCD-Panels und schreibe "meinem Chinesen", dass er die Panels in sein Angebot aufnimmt.
Die Zeit für das Eintreffen der Samples ist gerade "am Beginn". Von heute an innerhalb der nächsten 7 Tage rechne ich mit den Samples. Dann sehen wir weiter.
Co
« Reply #310 on: 23. November 2017, 10:31:23 »
Hello Andreas,
If I install the LCD with the damaged TS (damaged flatcable) it is impossible to execute the button test !! Holding the power button starts normally with the splash screen immediately followed by the button test screen specifying "POWER" and immediately followed by "POWERING OFF .." ,  then indeed powering off.
I gather entering the button test test would mean letting the power button go in the right split millisecond.
regards
Co
will check the battery.
Co
« Reply #311 on: 23. November 2017, 11:14:15 »
Thomas I agree that it could solve the 'blue screen' problem.
Regards
Co
DB2OJ
« Reply #312 on: 23. November 2017, 14:28:32 »
wie von Thomas bereits beschrieben ist das auch bei meinem
04 er mchf der Fall.
Nach Aufspielen einer neuen FW tritt der Fehler jedes Mal auf.
Danach muss ich einige Male ( 3-5 mal ) die Band - Taste zum Rebooten benutzen,
bis wieder normal gestartet wird. Davon haben ja auch schon andere OMs berichtet,
die keinen OVi40 betreiben.
Vielleicht könnt ihr doch die Abfrage des TP weglassen und die Ursachenfindung auf einen späteren Zeitpunkt legen.
Manfred
« Last Edit: 23. November 2017, 14:30:21 by db2oj » Logged
« Reply #313 on: 23. November 2017, 15:18:08 »
Hallo 20000er,
bitte sagt mal, wenn beim Start der Code 20000 kommt, was steht dann auf dem Display:
"Touch (no coord.)"
"Touch (no cntrlr)"
"Touch"
Stehen unten "x/y" und dann Zahlen?
oder macht einfach mal ein Foto.
Danach richtet sich die Fehlerbehebung / -vermeidung, die wir einbauen werden. Gänzlich ausschalten ist eine ungute Idee.
Wenn mein Verdacht bestätigt wird, dann werde ich ganz schnell eine Lösung haben.
Danke
Co
« Reply #314 on: 23. November 2017, 16:23:20 »
Hi Danilo,
two pictures
no 1. Immediately after the splash screen
no 2. after a random touch on TS
regards
Co
Pages: 1 ... 19 20 [21] 22 23 ... 25 Go Up Print
