Re:LCD Kit OVI40 Vers.V1.2
« Reply #46 on: 02. February 2019, 21:45:34 »
Vielen Dank, Slawek ! Ich denke, mit 7,5 Ohm für R 105 bin ich auf der sicheren Seite.
« Last Edit: 02. February 2019, 21:46:18 by DF5LI » |
73, Harri
« Reply #47 on: 03. February 2019, 11:30:53 »
The last kit from Andreas has 2,2 ohms for R105. Btw. i used 68µF for C103. Hopefully thats acceptable? Of course i would never unplug the live LCD under power.
« Last Edit: 03. February 2019, 11:31:20 by peter_77 » |
« Reply #48 on: 03. February 2019, 11:59:40 »
Hi Peter, as I said it depends on LCD module, if your lcd has no noticeable warm up - it is OK. Regarding the capacitor, I recommended the 100u but the truth is if you use anything equal or above 22u (X7R, X5R) will work. This capacitance is for blocking the dimming current.
« Last Edit: 03. February 2019, 12:00:19 by SP9BSL » |
« Reply #49 on: 03. February 2019, 12:23:30 »
Cześć! Slawek ! OK, sounds good. I could'nt notice any bigger warmup so i guess its ok. I also count on Andreas here, cause i assume he has tested that waterproof with the provided displays of his own kits ?! ![](YaBBImages/wink.gif)
On the other hand Andreas used in his ready made 3.5" displays a resitor labled "150" for R105 which i assume is 150 ohms ! A value which is pretty far away from 2R2 or even 4R7. The display panels itself look pretty much the same, so there are still some doubts why we have such a huge difference here...?? ![](YaBBImages/undecided.gif) Hopefully the 2R2 will not kill the LCD in a long term usage perspective..?!
Btw. here is the difference of C104 and C107 from the kit list and the ready assembled ones. You need to keep an eye here on the tantalum C104 and C107 polarity !
C104-107.jpg « Last Edit: 03. February 2019, 12:39:42 by peter_77 » |
« Reply #50 on: 03. February 2019, 13:00:39 »
no, resistor labeled 150 is 15ohm, last digit means ten multiplier like in ordinary thru hole resistors
« Reply #51 on: 03. February 2019, 13:30:42 »
Sorry, yes you are right with 15 Ω. But anyway, its still a huge difference to the provided 2R2 in the kit !
« Last Edit: 03. February 2019, 13:32:54 by peter_77 » |
« Reply #53 on: 04. February 2019, 08:16:36 »
As a conclusion is it then safe to replace the existing 15Ω on R105 on your older, ready assembled displays with the new value 2,2Ω ? Or maybe as a compromise with 4,7Ω cause i still have this value as a leftover from the I40 and SParrow assembly.
« Last Edit: 04. February 2019, 08:18:02 by peter_77 » |
« Reply #55 on: 04. February 2019, 15:13:32 »
Soo, ich habe endlich ein Datenblatt für das Display gefunden. Da findet sich eine Angabe über das Backlight: 8 x 15 mA parallel. Also wäre ein Strom von 120 mA noch innerhalb der Spezifikationen. Dann kann ich ja mit gutem Gewissen einen 2,2 Ohm Widerstand verwenden und mich über die Helligkeit freuen
73, Harri
« Reply #57 on: 04. February 2019, 17:02:12 »
Hello all, Harri, may I ask you to measure the voltage on LEDs with 2R2 resistor?
OE3HKC
« Reply #59 on: 04. February 2019, 20:16:01 »
Bei meiner selbst entworfenen LCD-Platine verwende ich einen 3E3 - Widerstand, auch 4E7 ist noch sehr brauchbar und die Helligkeit überzeugend bei keinerlei Erwärmung des Displays...
sende ein pdf mit Schaltung und Bestückungsplan mit... die Platine ist sowohl für meinen MiniTRX als auch für die OVI40-Version ausgelegt... 73, HKC aus dem Wienerwald
