Re:4-Zoll-LCD für uiOVI40-Platine
« Reply #45 on: 07. May 2021, 16:29:16 »
Hi Slawek !
Looks "The object on Aliexpress:" is not available with the ILI 9486 controller anymore. ![](YaBBImages/sad.gif) Do you maybe have an alternative where to order those compatible 4.0" LCDs ??
« Last Edit: 07. May 2021, 16:30:20 by peter_77 » |
positron alter Hase
« Reply #46 on: 07. May 2021, 19:37:51 »
Hi Peter, I'm very busy but somehow things go in right direction..
Of course I have an alternative, plenty of them on Ali (at least until "someone" will buy all of them for own business after this info ![](YaBBImages/smiley.gif) There is LCD from the same seller but marked as "ST7796 touch". Give me few days until I add new driver to official firmware:
![](https://sp9bsl.pl/pic/SParkle_ST7796.jpg)
As stated before here, the 4" lcd is so big that freq knob overlaps it partially, I've designed special board for few types of 4" and one 3.5" with removed support for mcHF. Since Chris decided to remove parallel conection from 6.3 boards the connectors are not needed anymore. The additional small break-off board moves the freq knob out of lcd area:
![](https://sp9bsl.pl/pic/P138_4_top.jpg)
![](https://sp9bsl.pl/pic/P138_4_bot.jpg)
« Last Edit: 07. May 2021, 20:30:15 by SP9BSL » |
satoryboy
« Reply #47 on: 10. May 2021, 09:57:22 »
I'm looking forward to binding the ST7796 controller in the firmware. It is very close to ILI9486 in datasheet specification. Thanks for your work, 73!
satoryboy
« Reply #48 on: 14. May 2021, 11:40:04 »
I still look forward to the ST7796 driver in the source code of the UHSDR firmware. There is a ready-made debugged 4 "transceiver, there is a 4" display with this controller. I really want to marry them )).
positron alter Hase
« Reply #49 on: 14. May 2021, 12:46:56 »
Hi, recently there was huge change in display driver code, I must (and want to) follow that beacuse I'm a part of the team. You abandoned the teamwork within UHSDR project so my advice to you is: you have to wait.
« Reply #50 on: 14. May 2021, 17:15:10 »
Slawek, looks great ! Thanks for the feedback ! Let me/us know when it works and the Ali URL.
satoryboy
« Reply #52 on: 17. May 2021, 05:59:21 »
I am still waiting for a commit to the UHSDR repository active-devel.
satoryboy
« Reply #54 on: 18. May 2021, 14:52:17 »
Sure.
Slavek SP9BSL, hello. Can you share the firmware source code for the ST7796 driver with me? Is it possible? I'll deal with the driver myself, time is expensive. 73!
positron alter Hase
« Reply #55 on: 24. May 2021, 08:31:37 »
Code is available in my repo since few months. I'm suprised you did not checked that. Look there and check commits in directsampling-dev branch, this is our main construction site now. Next some updates will be pulled to active-devel too.
satoryboy
« Reply #56 on: 24. May 2021, 08:41:03 »
I searched, but did not guess to look in this repository. Thanks and 73!
satoryboy
« Reply #57 on: 24. May 2021, 09:49:46 »
There is no ST7796 controller driver in the directsampling-dev and sparke_integration repositories. I need help.
#ifndef EXTERNAL_USE_GFX_CONFIG #define USE_GFX_ILI932x #define USE_GFX_ILI9486 // SSD1289 support is not yet working, also requires USE_GFX_ILI932x to be enabled for now. // #define USE_GFX_SSD1289 #define USE_DISP_480_320 #if defined(STM32F7) || defined(STM32H7) #define USE_GFX_RA8875 #endif #endif
« Last Edit: 24. May 2021, 09:51:57 by satoryboy » |
satoryboy
« Reply #59 on: 24. May 2021, 12:58:21 »
Here is a screenshot of the same page, I just don't see these commits, github glitches?
