19. April 2025, 00:15:59
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: IC7 <- zurück vorwärts ->
   Author  Topic: IC7  (Read 2068 times)
sm0nor
IC7
« on: 11. February 2018, 13:58:04 »
About IC 7...
Is this IC supplied in bag 3 (photo) the same as the AT24CM02 specified in the BOM?
It ought to be as it is the only one matching the pin konfiguration. But, better safe than sorry...
How about the pin configuration?
/Ulf
SM0NOR
Re:IC7
« Reply #1 on: 11. February 2018, 15:15:53 »
And the little, barely visible dot is the pin 1-marker.
Re:IC7
« Reply #2 on: 11. February 2018, 15:20:25 »
standard-guide: If direction of text si in "readable position" left bottom is pin 1
sm0nor
Re:IC7
« Reply #3 on: 11. February 2018, 19:59:29 »
Quote from: DL8EBD on 11. February 2018, 14:49:00
and please leave R101 open
I soldered it, but I see now on the diagram that it is optional. So, depending on the type the 0 ohm resistor should be either in place or not in place. Correct? And for the IC type I have, it should not be in place? Correct?
/ulf
