Pages: [1]
Topic: Is OVI40-UI capable to drive mcHF RF? (Read 1955 times)
Mike-K0JTA
![*](YaBBImages/star.gif)
« on: 23. April 2018, 19:28:11 »
Can I plug your UI board into a mcHF version .4 PA board? (And have it function as desired or expected?
I have an mcHF radio that has no PTT, but it transmits ten watts in TUNE mode. (Just SSB and AM modes are bad, as there is NO PTT action at all.) The receiver, etc. all works wonderfully, just no PTT. (But the TUNE mode does emit a ten watt carrier!)
It is my desire to be able to plug in your UI PC board, and have a functional transceiver.
Will your UI board fill this need?
Are the interconnect pin-connections COMMON between your UI board and my version .4 mcHF PA board?
Thank you; Mike, K0JTA
Re:Is OVI40-UI capable to drive mcHF RF?
« Reply #1 on: 24. April 2018, 05:26:20 »
yes, it will work. mcHF RF 0.4 - 0.6 RF board and OVI40 share the same 30 pin connector. OVI40 has additional connectors but these are not required for the mcHF RF board.
« Last Edit: 24. April 2018, 06:12:41 by DF8OE » |
Pages: [1]
