13. April 2025, 18:54:35
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: Problem UI with STM32H734ZIT6 <- zurück vorwärts ->
   Author  Topic: Problem UI with STM32H734ZIT6  (Read 5271 times)
yeson
I'm a llama!
« on: 25. August 2022, 07:21:23 »
Processor STM32H743ZIT6V  The DFU can see in PC but the Dfuse Demo v.306 cann't Program and I check some key piont.
Power 3.3V is available.
Reset (25 foot) C94 with 57KOhm works - rises to 1.9V.
The IC5 (ASTX-H11) 3-pin provides a 16MHz signal with a 1.7V amplitude.
« Last Edit: 25. August 2022, 07:37:50 by yeson »
yeson
I'm a llama!
Re:Problem UI with STM32H734ZIT6
« Reply #1 on: 25. August 2022, 07:24:56 »
After that I programmed with ST-Link V2.
Bootloader to 0x08000000 Fireware to 0x08060000. I think to MCU cann't not run
yeson
I'm a llama!
« Reply #2 on: 25. August 2022, 07:28:47 »
bootloader write to 0x08000000
yeson
I'm a llama!
« Reply #3 on: 25. August 2022, 07:30:05 »
Fireware write to 0x8060000
yeson
I'm a llama!
« Reply #4 on: 25. August 2022, 07:33:13 »
MCU core menu
yeson
I'm a llama!
« Reply #5 on: 25. August 2022, 07:41:41 »
I try to use STM32cubePorgrammer. But it sitll not work
yeson
I'm a llama!
« Reply #6 on: 25. August 2022, 07:42:56 »
STM32CP02
yeson
I'm a llama!
« Reply #7 on: 25. August 2022, 07:44:02 »
STM32CP03
yeson
I'm a llama!
« Reply #8 on: 25. August 2022, 07:45:06 »
STM32CP04
yeson
I'm a llama!
« Reply #9 on: 25. August 2022, 07:46:20 »
STM32CP05
yeson
I'm a llama!
« Reply #10 on: 25. August 2022, 07:50:41 »
After Programed.I Press Power.There is nothing display just a white bakground. I try to press Power + (Band+ or Band-).it cannot entry to bootroader menu. still nothing displayed.
« Reply #11 on: 25. August 2022, 07:53:50 »
I have not programmed STM32 for a long time but I remember that STM32*7 sometimes have scrambled BOOT_ADD0 and BOOT_ADD1 which must be set manually with stlink. I am working on Linux console and havbe not any skills on Windows applications.
yeson
I'm a llama!
« Reply #12 on: 25. August 2022, 08:03:33 »
In the  Option bytes
BOOT_ADD0 = 0x08000000
BOOT_ADD1 = 0x1ff00000
Is it the correct address for booting?
« Reply #13 on: 25. August 2022, 11:58:16 »
Pse look here and enter pattern "BOOT_ADD".
yeson
I'm a llama!
« Reply #14 on: 26. August 2022, 01:53:19 »
I read the datasheet. edit the Boot address option bytes. the DFU work.
BOOT_ADD0(H) 0x0800 Boot from(H) 0x08000000
BOOT_ADD1(H) 0x1FF0 Boot from(H) 0x1FF00000
The DFU mode can Program. But MCU still not working.The Hold broad current just 50~60mA. The P6 is took off.
Mcu core page:
« Last Edit: 26. August 2022, 04:53:56 by yeson »
