Pages: 1 [2] 3 4 ... 6
Topic: neues Noise Reduction - Feedback (Read 10155 times)
PY3CRX_PY2PLL
![*](YaBBImages/star.gif)
Re:neues Noise Reduction - Feedback
« Reply #15 on: 03. December 2017, 10:53:38 »
Hi Frank et al
Later I found adjustable parameters under debug menu ( they're always there )
I'll keep watching / testing, when I report abt memory was just a feedback. My last version before 2.7.15 was the one which introduced touch screen (may be +1 year old).
Last night I loaded 2.7.35. If NR VAD type = Sohm the red led does not flick with modulation (always lit) , for any NR threshold value. When using VAD = Esch & Vary then it's possible to make it flick with thresh ~5500.
Marcus Ramos PY3CRX + PY2PLL S B Campo - SP - BRA GG66rf
dg9bfc_sigi
DG9BFC
« Reply #16 on: 06. December 2017, 11:06:52 »
also with sohn it does flicker (depending on value setting) .... but it does not always "engage" ... sometimes you have to turn up the value so red led goes off (or better say does flicker with voice)
the programmers are still working on the nr and notch ...
tests should be done with version 39 (last one)
if you wanna use the "old" nr ... last version with old nr and old notch filter is 31 ...
you wrote you tested with 35 version .... hmmm i am guessing that there is some work done between 35 and 39 so better use newest version for tests and report your findings ... as far as i can remember the value settings for threshold were scaled to be in the same value range for both settings in one of the versions but i do no remember exactly what version number it was ... (i would have to dig through the commits to know what number it was) ... so use newest please
greetz sigi
« Reply #17 on: 07. December 2017, 17:19:18 »
Hallo Frank, ich habe mir heute erst deinen Beitrag im Wiki durchgelesen. Was für eine schöne Fleissarbeit! Hut ab!! Bei den zur Zeit herrschenden schlechten Bedingungen im 80m-Band ist die von dir entwickelte Implementation eine echte Hilfe und ein großer Fortschritt! Ich befürchte nur, dass dein englischer Text beim durchschnittlichen OM Waldheini nicht viel zur Erleuchtung beitragen wird... Den Eindruck hatte ich jedenfalls in mehreren Gesprächen mit "Nur-Benutzern" des UHSDR. Aber in dem Fall zählt das Ergebnis, und das ist mehr als überzeugend !! Es gab im Verlauf der anderthalb Jahre, in denen ich mich mit dem mcHF beschäftige, einige Highlights, die das Gerät seit den KA7OEI - Zeiten vorangebracht haben, und deine Arbeiten gehören mit Sicherheit dazu!!
Das musste ich mal loswerden ;-))
73, Harri
« Reply #19 on: 13. December 2017, 16:47:41 »
Habe heute, nachdem die neue NR Funktion auf dem I40 so gut rennt, mal die Ver. .43 auf einen mcHF gespielt und die NR Funktion aktiviert mit dem Wert "3" wie es auch im I40 rennt. Sobald man das tut und der Balken zur Werteingabe sich öffnet erklingt zusätzlich zum normalen Rauschen ein deutlich wahrnehmbares rythmisches Geräusch im Lautsprecher und die rote LED blinkt im Takt dazu (ca. 2 Hz) was nicht mehr verschwindet. Es sei denn man schaltet NR wieder ab. Beim I40 passiert das nicht. Ist das jetzt der Tatsache geschuldet das der Prozessor im mcHF damit überfordert ist, quasi die NR Funktion dort dann eigentlich nicht nutzbar ist, oder woher könnte das kommen ?
« Last Edit: 13. December 2017, 16:49:16 by peter_77 » |
« Reply #21 on: 14. December 2017, 12:02:54 »
Ich habe das heute mal etwas genauer untersucht und herausgefunden das der Bruch genau zwischen dem Release .31 und .32 passiert. .31 ist noch sauber macht keine Geräusche aber ab .32 geht es los das dort eine rythmische Taktung mit 2 Hz zu hören ist ohne Antenne. Mit den .40er Releases sind sie sogar noch lauter geworden und in der Taktung etwas langsamer. Mit Antenne und ohne Signal hört man weiterhin deutlich diese 2 Hz Taktung sobald die NR mit dem Wert 3 z.B. aktiviert ist. Schaltet man NR aus ist das Geräusch verschwunden bei den Releases oberhalb .31
Ich habe das auf 3 ! mcHFs mit 05er und 06er UI und RF reproduzieren können. Allesamt laufen im SPI Mode (Uhren Mod installiert). Ich kann es leider nicht auf einem Parallel mcHF testen da ich keinen mcHF mehr im paralell Mode habe. Ggf. kann hier einer der Forenmitglieder aushelfen ?! Möglich das dieser Effekt nur im SPI Mode auftaucht, denn der I40 der ja im Parallel Mode rennt zeigt dieses Verhalten nicht.
« Last Edit: 14. December 2017, 12:03:54 by peter_77 » |
« Reply #23 on: 14. December 2017, 16:59:34 »
Ich habe das eben nochmal mit einem befreundenten OM via Telefon verglichen. Der hat auch SPI und das Problem nicht. Ich konnte es selber hören grrrr... Er aber auch mein 2 Hz "Tackern". Einziger Unterschied ist das er dein 3,2 Zoll Display im SPI Mode nutzt und ich eben das Standard 2,8er. Wir haben die AGC Einstellungen verglichen und gleich gesetzt. Ich habe übrigens immer nur die WDSP AGC aktiv nie mehr die alte. Allerdings haben wir nur die AGC Settings verglichen. Ich vermute das es eine andere Einstellung ist die das bewirkt. Deine Frage ist berechtigt ...nur welche ![](YaBBImages/huh.gif) Wir müssen dann vermutlich doch mal alle Einstellungen einzeln durchgehen....hilft wohl nix. Es lässt sich aber auf allen 3en wunderbar reproduzieren wenn NR aktiv ist. Spiele ich die .31 ein = alles gut Bootet die .44 = 2 Hz "Tackern" ![](YaBBImages/angry.gif)
Evtl. mal einen Reset auf die Standardwerte und checken. (Wie ging das noch ??) PA Einstellungen muss ich dann vorher notieren
« Last Edit: 14. December 2017, 17:05:59 by peter_77 » |
DD4WH
positron alter Hase
« Reply #25 on: 14. December 2017, 18:54:10 »
Hallo Peter,
das ist vertrackt.
Erstmal: ab ver. 32 ist die NEUE NR mit der DSP box schaltbar, vorher (31 und kleiner) hat die DSP box die ALTE NR geschaltet.
Wenn Du also die NR immer mit der DSP box schaltest, sollte zwischen ver. 31 und ver. 32 ein riesiger Unterschied sein, das ist normal, da Du ja mit der DSP box bei ver. 31 die ALTE NR einschaltest, und bei ver. 32 die NEUE NR.
Aber ein 2Hz-Tackern ist mir noch nicht untergekommen.
Was passiert denn, wenn Du bei der ver. 31 die NEUE NR im DEBUG-Menü einschaltest? Ist die dann auch mit 2Hz unterlegt?
Ich könnte mir nur vorstellen, dass durch das Springen zwischen den Versionen ein Wert im EEPROM merkwürdig gesetzt ist und dadurch irgendwelche Einstellungen zerschossen sind.
Könnte natürlich auch ein bug sein, denn auf gleich drei mcHFs die Einstellungen simultan zu zerhauen, ist natürlich nicht einfach.
73 Frank
« Reply #27 on: 15. December 2017, 09:38:13 »
Habe auch immer nur Magnify x1 an. Das kann es also nicht sein... ![](YaBBImages/wink.gif)
Frage ist welche Einstellung darauf Einfluss haben könnte bzw. WAS hat sich zw. der Version .31 und .32 genau geändert ![](YaBBImages/huh.gif) Denn genau ab diesem Releasesprung tritt das auf.
« Last Edit: 15. December 2017, 09:45:23 by peter_77 » |
DD4WH
positron alter Hase
« Reply #28 on: 15. December 2017, 09:44:37 »
Hallo Peter,
wäre schön, wenn Du mal ausprobieren könntest, ob der Fehler nach Rücksetzen der Konfiguration auch noch auftritt. Dadurch bekommt man eine Idee, ob es ein Konfigurations- oder ein hardware-Fehler ist. (Oder ein software-bug, der durch eine merkwürdige Einstellung provoziert wird)
Beste Grüße,
Frank
« Reply #29 on: 15. December 2017, 09:48:11 »
Wenn ich bloß noch wüsste wie das geht...? Handbuch lesen hilft vermutlich ![](YaBBImages/wink.gif)
Ich denke mal die Vorgehensweise ist: Gesamt Konfig sichern vorher und dann Factory Reset, richtig ? So kann man die vorherige Konfig aus dem EEProm wiederherstellen denke ich.
Was übrigens noch interessant ist: Öffnet man das Konfig Menü verschwindet das "Tackern" sofort. Schliesst man es wieder ist es wieder da.
« Last Edit: 15. December 2017, 10:01:35 by peter_77 » |
