12. April 2025, 11:16:54
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: Bad PA job outside of amateur bands <- zurück vorwärts ->
   Author  Topic: Bad PA job outside of amateur bands  (Read 2566 times)
« on: 13. May 2018, 21:03:03 »
Hi
« Last Edit: 29. June 2022, 21:06:56 by SP3OSJ » Logged
Re:Bad PA job outside of amateur bands
« Reply #1 on: 14. May 2018, 07:27:19 »
Hi Artur,
not a bug - its a feature. Power out level is reduced dramatically outsinde the amateur bands included 11m band. There is no country on our planet where you can legally use a homebrew rig for 11m working.
It is a safety feature so that nobody can xmit there by accident. And there is no reason for transmitting outside the bands with high power  . Only for measurement purposes - a few mW is enough.
pa3met
« Reply #2 on: 14. May 2018, 12:02:14 »
on the other hand, if you want to drive a transverter I could think of the use of such frequencies. Obviously extreme high levels shoudl not be useable
Somethink like 26.....30 MHz to cover 4 MHz in the 70 or 23cm band. Or maybe even 144.....148 MHz transverters,
For 11m... well I fully agree on that one. (including the other bands, like 45m, etc the pirates seem to use)
« Reply #3 on: 14. May 2018, 15:43:50 »
for the transverter use case you are right, and this might be a use case which we could support at some point. I indicated that to Artur, SP3OSJ in a different there in this forum, where I also mentioned the low power rule outside amateur bands.
In order to have somewhat consistent power output and TX IQ across a larger freqency range, we would need to add more calibration points and some other stuff. So it is most likely not a simple `we turn that "stupid" limitation off` thing.
« Reply #4 on: 14. May 2018, 18:42:48 »
And for the 1000th time I write:
I do not think it is a very good idea to take mcHF for transverter use or put a big PA to it. Signal quality - especial on higher frequencies > 20MHz - is not good enough to do so.
Bandfilters are designed for HAM bands usage. Some "outside bands" are covered because of the bandwidth - but most are not. So you will be captured in mountain-like peaks and deep dampings. If you want ot use transverter you have to do more hardware modification:
- add two low level output/input which are connected directly behind TX mixer and before RX preamp input
- do filtering exactly to the used span externally
- reduce modulation level so that you will reach better signal quality
I think it would be better to use another rig for transverter purposes...
« Last Edit: 14. May 2018, 20:01:32 by DF8OE » Logged
