12. April 2025, 11:17:03
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: Bootloader 4.1.1 / Firmware 2.9.43 ok?? Please confirm here! <- zurück vorwärts ->
   Author  Topic: Bootloader 4.1.1 / Firmware 2.9.43 ok?? Please confirm here!  (Read 1590 times)
« on: 21. July 2018, 11:24:01 »
we are actually at the stage that we can merge H7 port of Danilo to active-devel. But we need some more reports that everything at the version of the thread title is ok.
So please report here if you have a working set and
  • updating to this worked flawlessly
  • you have not lost any configuration
  • updates using USB stick with the new bootloader also works (you can update with the same firmware version to see if it works - if there is no error *it works*)
Reports are highly welcome. Please attach processor type (F7/F4/F4_small).
Re:Bootloader 4.1.1 / Firmware 2.9.43 ok?? Please confirm here!
« Reply #1 on: 21. July 2018, 14:45:23 »
an OVI40 ui1.7 Bootloader 4.1.1 und FW xxx.43 via USB-Stick update.
Dabei keine Probleme
Funktionen aktuell ohne erkennbare Besonderheiten
