12. April 2025, 11:18:03
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  UHSDR Firmware (Moderators: DF8OE, DL1PQ)  |  Topic: new builds now officially supports H7 MCU on OVI40 <- zurück vorwärts ->
   Author  Topic: new builds now officially supports H7 MCU on OVI40  (Read 2000 times)
« on: 22. July 2018, 09:12:34 »
Hi to all,
I have merged Danilos H7 implementation and modified my "automatically build script". First build has new version numbers (for mcHF/OVI40-F7, too). There is no functional change but it would be helpful if you can test functionality.
Re:new builds now officially supports H7 MCU on OVI40
« Reply #1 on: 22. July 2018, 21:10:25 »
F4 with both displays works.
Naming changed for H7 files - important!
« Reply #2 on: 25. July 2018, 04:52:04 »
Hi to all,
I have done a mistake - but only a handful are bothered.... I haven't changed namings for bootloader and firmware file for H7 builds so they are identical to F7 builds - not good. Confusion and bugreports would be the result.
So I changed namings for H7 builds to
fw-OVI40
bl-OVI40
and that are the filenames which are hard-coded in bootloader for USB upgrades. Very sorry I forgot that. I removed bootloader and firmware from server and replaced them with versions added a "h" after the version string. This is a quick hack only for this build (I didn't want to count all versions one up for this change).
All who do own H7 board AND have already installed bootloader 4.1.2 / firmware 2.9.44 are pleased to install the now available versions so that USB upgrades will depend on the correct filenames.
Starting with next version of bootloader / firmware the above naming is default.
...and because of H7 would become standard MCU when it is available in masses naming is now corresponding to project name
