News: Bootloader 5.0.3 and Firmware 2.11.9
« on: 13. January 2019, 15:42:02 »
we got a lot of requests regarding the failing reboot after an firmware update via usb drive. Well, bootloader 5.0.3 fixes that. So get it, if you don't like the current way.
There is also the firmware 2.11.9 released, which contains an improved PA level control and display. The background color is now used to tell you if everthing is as expected. See short info here: https://github.com/df8oe/UHSDR/wiki/Operating-Manual#output-power-display-explained. Among other colors, a red backgrround now indicates missing calibration, hence output power is 0 although you are able to transmit, you won't get a signal.
