Topic: Mod-fw of UHSDR 2.11.87m1 (all rigs) (Read 5865 times)
satoryboy
« on: 11. June 2020, 04:26:10 »
Hello, I am posting a new version of my firmware based on the current stable version of UHSDR - 2.11.87m1, for all existing versions of the M0NKA transceiver. So, what is implemented
(including previous versions)?
- The range adjustment options forgotten by the developers are added and the relative order in the menu is made. - The "Tune Helper" option in the Display Menu is saved in the config, the "Show CW LED" option at the request of the comrade returned to "ON" by default. - Peak indicator S/PWR meter - the delay is spinning (0 = OFF) in the Dysplay Menu -> Peak Ind. Timer, sec. Still needs refinement. - Added colors in the palette. Setting the default color of on-screen indicators-buttons - Dysplay Menu -> Boxes Color. - Two monochrome firmware, b/w and sepia. If you cut the style of the "Gray" waterfall, it’s very stylish. - Encoder reverse capability - Configuration Menu -> Encoders 1-3 Reverse / Encoder 4 Reverse. Good help to those who assemble the transceiver. - Operating mode with the so-called presets (receive frequency, mode, filter settings) MEM. A very useful thing in everyday life and in production )). For each range, including the Gen
wild zone, 4 presets M1 ... M4 are allocated. This mode is activated by long pressing F3 (SPLIT). Preset recording - long press Mx, using - short. Short press F3 (MEM) - call the list of
these presets, and you can work with them without closing the list. Closing the list - by short or long pressing F3, in the latter case we exit the MEM mode (whether the list is open, do
not care) to the main mode of operation of the Fx buttons. - Added tuning steps of 5 and 50 Hz. - The CW decoder is disabled (if turned off in the menu) in transmit mode. - Compact U/L sideband display. - Added missing adjustments for 6m band, as well as the missing option to adjust the power display at 28 MHz. - On-screen menu for direct mode selection. It is called up by a short press on the indicator-button of the mode. - The mode of working with CW macros has been improved — the 4th macro cell has been added, and the playback modes have been added - CYCLED (pause - CW Mode Settings -> CW
MacroCycledInterv, sec, default 3 sec.) And the BEACON (pause - CW Mode Settings -> CW Beacon Interval, min., By default 3 min.). Modes are switched by long pressing F5. Also added
"accelerator" macro playback 1, 2 (CW Mode Settings -> CW Fast Macro 1,2). If enabled, the first 2 macros are played at maximum speed, 48WPM, the 3rd and 4th are set. The idea is to speed
up the "599" and the long "?". However, to whom what. For DX big and warm hello)). Just in case, who is not in the know - you can interrupt playback by briefly pressing F5, or starting the
transmitting with the key. - At the request of the comrade, added a battery of CW filters with a width of 100 and 200 Hz. Himself in shock, how cool they work )). - Added the ability to enable the S-meter operating mode in AM not by the carrier, but by the useful signal - Dysplay Menu -> S-Meter NotLO in AM. - Added the option to disable the "frozen" panorama in TX (Dysplay Menu -> Clear Panoram on TX), with a large pathos inscription "TX" in the most visible place)). In SSB OK, in CW for an
amateur, I myself did not like it. Up to you! - At the request of the comrade from Spain, added a touchzone in the RIT indicator - with a short poke, the RIT is reset. - Added action for the touch zone to reduce the panorama scale - with a long poke, the scale jumps to 1: 1. - SWR protection, if enabled, is blocked at an installed power of 0.5 W - the detectors cannot cope. - Test transmission mode eSSB with a band of 6 kHz. To do this, select "eSSB 6k" from the "Filter Selection" menu in the "SSB TX Audio Filter2" option. - Fixed bugs found.
Implemented in earlier versions: - A full-fledged screen interface with a panorama in the entire width of the display 320 × 240 (for displays 480 × 320, 800 × 480 this has already been implemented). Switching between
interfaces - long press F1 (MENU) if there were no saved configuration changes. The new interface can be specified as default - the first Display Menu option. - BndMem marker visibility - Display Menu -> Don't show BndMem. - Peak indicator in S/PWR meter. - Improved virtual band selection keyboard. - A virtual keypad for direct dialing of the tuning frequency has been added for the display 320x240 (for displays 480x420, 800x480 this has already been implemented). The keypad is hung
by a long press of the touch zone of the "senior" signs of the tuning frequency indicator. It also works in the default interface 320x240. - Added the option "Band +/- BndCh / Jump Swap" to the Configuration Menu - if you turn it on, a short press of BAND - / + will become tied to a frequency jump across the width of the
panorama (I am quietly proud of this refinement, it’s a very useful thing with a kutsy panorama of 48 kHz ), and long - to change the band. By default, vice versa. Dramatically improves
the efficiency and convenience of working on the air. And more logical in terms of interface friendliness. - At the request of the comrades, covered the “fence” of the panorama grid from above. In the default interface, I did not do this for marketing reasons )). - I put the relative order in the Setup Menu - UHSDR made a complete mess in it and devastation, it infuriates. - Unlocking transmissions on civilian CB bands, see Debug/Exper. Settings. - Fixed bugs found.
I also post a modified version of the UHSDR loader 5.0.4m, which can save to a flash drive and load the configuration in binary format. Together with the firmware backup file, the CF-
MCHF.OLD configuration backup file is also written to the flash drive. If the loader finds such a file in the root folder of the flash drive at boot time, it will load the configuration.
Work is done only with the flash memory of the processor, accordingly, you need to do backup from the external memory in the menu and, accordingly, restore the configuration. There is no
version control, be careful. 73!
Fw - https://yadi.sk/d/IztsydWjBzhTUA
Bootloader - https://yadi.sk/d/H9ePUm9W7Nryhw
Source - https://yadi.sk/d/R7Hh_yI0ATLXJg
satoryboy
Re:Mod-fw of UHSDR 2.11.87m1 (all rigs)
« Reply #3 on: 11. June 2020, 12:13:10 »
To DL8EBD
Please try again. I did not find errors in the posted archive.
To DF8OE
Sorry, I'm a bad programmer. If you take useful improvements to the overall project, it is better to do this to a qualified programmer. In addition, my project for band balancing of the TX mixer was rejected even without discussion. Meanwhile, the hardware-software mode has already been repeated by several hams and the results are very good. Even with a serious dependence of the carrier suppression on the signal level, a very good carrier suppression is obtained, much more than 50 dB.
« Reply #7 on: 11. June 2020, 19:53:04 »
It is a pity that good ideas are blocked.
Which one??? Please specify. All you needed for your business was added. Why do you complain? Just for another fight? Everytime if there is something to complain you appear, I would quote you: "it is not fair".
----------- In general: Yuri involved a lot of work but during commits refused comments to be compatible with main code and github rules as Andreas wrote. If there is possibility to rebase the code in his archive - good for his work, if not hmm... I see no future for this.
Just my two cents...
--- Yuri: can you share the knowledge about "Fixed bugs found"?
« Last Edit: 11. June 2020, 20:18:17 by SP9BSL » |
satoryboy
« Reply #9 on: 12. June 2020, 00:08:05 »
To DF8OE
Yes. Direct transition to the frequency by pressing in the wide panorama mode works well.
To DL8EBD
Thanks for clarifying the processor. I only have a device with F4. I really hurried with mass compilation. The error file was compiled again and reloaded the archive into the cloud. Please check the full color firmware. Thank you.
To SP9BSL
For example, displaying the tune indicator in a panorama in SPLIT mode. I can’t list everything quickly, I need to look at the source change logs.
