Co
SI5351 and OVI40
« on: 04. January 2021, 15:33:50 »
Hello to all,
I have a spare populated OVI40 ui-board for which I made frontend with a 'potato' mixer and a SI5351 oscillator with 2 outputs and 90 degr. phase shift. Presently the SI5351 is controlled with a teensy. The IQ output is fed to OVI40 ui-board. It works quite well. Question: How do I activate the SI5351 routines available in the OVI40 software? recompile?
Kind regards and a prosperous (and above all a healthy) 2021.
Co
Co
Re:SI5351 and OVI40
« Reply #2 on: 05. January 2021, 15:37:58 »
Hello Andreas,
Tnx for your response. Unfortunately I am using a 25 Mhz xtal for the SI5351. So it will have to wait until the 27 Mhz xtal arrives.
Kind regrds
Co
Co
Re:SI5351 and OVI40
« Reply #4 on: 17. January 2021, 15:34:37 »
Hello Andreas,
In the mean time installed a 27Mhz xtal. All works nicely . The vfo covers even 50 and 70 Mhz. The SI5351 is however in need of calibration. On 3.5 Mhz the deviation is approx. 100 Hz. Is the calibration option, as per the configuration menu, also implemented for the SI5351 ?
Kind regards
Co
Co
Re:SI5351 and OVI40
« Reply #6 on: 17. January 2021, 19:09:12 »
Andreas,
That is clear. The reference correction is applied when the PLL frequency is being calculated which is performed next to the calculation of the multisynth divider values. In this calculation (specifically the PLL) the 27 Mhz crystal comes into play. So eventual deviation of the xtal from 27 Mhz. should be corrected by a fixed value. For the SI570 this is done via the callibration (debug settings). Does this apply also to the SI5351 ?
Regards
Co
Co
Re:SI5351 and OVI40
« Reply #8 on: 18. January 2021, 12:36:47 »
Hi Danilo, Andreas,
You were quite right. The callibration as per the configuration menu works excellent and works for both SI570 and SI5351. I referred to a method often used for the SI5351 i.e. correcting the deviation of the reference xtal.
Kind regards
Co
