Pages: [1]
Topic: News for F4-MCU (mcHF) starting with firmware 2.7.71 (Read 1952 times)
![](YaBBImages/exclamation.gif) |
« on: 28. January 2018, 10:04:48 »
Due to many new features and bugfixes we have reached the edge of small F4 MCUs with 512KB flash. Complete firmware will no longer fit to these MCUs.
Firstly we recommend, if possible, to swap MCU to 427/429/439 which does have more flash and additionally more RAM. So if you swap the MCU it is a good idea to take one of these MCUs. If you already do have MCU with > 512KB flash all is ok and you must not worry about anything.
We know that there are some MCUs with only 512KB out in the wilderness. To continue support for these MCUs we decided to add a new build for these MCUs. There are two builds for F4 (mcHF) starting with 2.7.71
- standard build which includes all features, runs on F4 with > 512KB flash
- small build where freeDV is removed that runs on F4 MCUs with 512KB flash
You will not be able to flash "standard build" to devices with 512KB MCU!!!
You can identify the version of firmware that is running at the leading letter which is present on all "official builds": "D" means "standard build" "S" means "small build"
Firmware will grow in the future again and will cross the border for 512KB MCUs again. So we gain time by providing these two builds, but the best solution is to swap the MCU. --------------------------------------------------------------------------------------------- Die Zahl der implementierten Features und Bugfixes hat die Größe der Firmware so weit ansteigen lassen dass ein "normaler standard build" größer wird als 512KB. Das bedeutet, dass man die "normale Firmware" nicht mehr in die 512KB MCUs flashen kann.
Wir empfehlen allen, die noch die kleine MCU haben, auf eine 427/429/439 aufzurüsten, um auch in Zukunft den vollen Leistungsumfang der Firmware zu erhalten. Zusätzlich zu mehr Flash haben diese drei MCUs auch mehr RAM. Wenn schon umgelötet wid, dann am besten gleich auf eine dieser MCUs. Wer schon eine MCU mit mehr als 512KB in seinem Gerät hat, braucht sich über nichts Gedanken zu machen. Für ihn ändert sich nichts und er muss auch nichts verändern.
Für die, die aktuell nicht umrüsten können oder wollen werden wir beginnend mit der Version 2.7.71 zwei Firmware-Versionen für den F4 (mcHF) anbieten:
- einen "standard build" mit allen Features für MCUs mit > 512KB Flash
- einen "small build" für MCUs mit 512KB Flash, bei dem das Feature "freeDV" fehlt
Den "standard build" kann man nicht auf Geräte mit der kleinen MCU flashen!!
Im Menü melden sich die offiziellen Builds der Firmware wie folgt: "D" ist die standard Firmware "S" ist der "small build"
Dadurch werden wir auch in Zukunft die kleinen MCUs weiter unterstützen können. Sicher wird die Firmware irgendwann erneut an die Grenze stoßen, weswegen langfristig wirklich das Wechseln der MCU die einzig wahre Lösung ist. Aber durch diese Umstellung bekommen wir erstmal eine ganze Weile Ruhe.
« Last Edit: 28. January 2018, 19:23:55 by DF8OE » |
OE1FHB
Re:News for F4-MCU (mcHF) starting with firmware 2.7.71
« Reply #2 on: 28. January 2018, 11:37:27 »
Hallo Andreas ! Die MCU STM 32 F 405 VG sollten nicht betroffen sein,da deren Flash 1024 kB groß ist ![](YaBBImages/huh.gif) Oder gilt die EINSCHRÄNKUNG auch für diese Type ??
vy 73 Friedrich OE1FHB
OE1FHB
« Reply #4 on: 28. January 2018, 14:34:40 »
Danke für die Antwort, war unsicher, weil der 405VG nicht angeführt wurde, aber F427,F429,F439 doch. ich Vy73 Friedrich
OE3HKC
« Reply #5 on: 28. January 2018, 20:03:44 »
soweit ich gesehen habe, gibt es nur mehr den Typ STM32F407VET6, der mit 512k noch in Umlauf sein könnte. Chris (M0NKA) hat ihn in seiner BOM für die revo5 zuletzt angeführt. Für die rev06 hat erdann bereits den Typ 407VGT6TR mit 1MB angegeben. Ich für mich habe zum Glück gleich zu Beginn die BOM von Andreas gewählt und deshalb in meinen ersten mcHF gleich den 405VGT6 mit 1 MB bestückt.... Also hat es sich bezahlt gemacht, gleich auf die Kompetenten zu hören.. ![](YaBBImages/smiley.gif)
Mein MiniTRX bekommt jetzt ein neues face, nämlich als Herzstück einen F/H7 Prozessor und darf dann auch die OVI40 SW verwenden mit dem schönen großen neuen 3,5"" Display...
das geht für mich schneller, als die SW so weit zu erlernen, dass ich eigenständige Änderungen vornehmen kann...
vy 73, Helmut aus dem WIENERWALD
Pages: [1]
