allgemeine Kategorie => Selbstbauprojekte => Message started by: Silphase Tech. on 05. November 2019, 09:16:08
Title: Silphase R1 SDR DCC Receiver
Post by: Silphase Tech. on 05. November 2019, 09:16:08
Sehr geehrte Damen und Herren.
Wie ich Ihnen versprochen habe, haben wir unsere Website gestartet, auf der Sie unser neues Produkt Silphase R1 Receiver sehen, eine Vorbestellung vornehmen und echte Videos auf dem Youtube-Kanal sehen können.
Für weitere Informationen stehe ich Ihnen gerne zur Verfügung.
Mit freundlichen Grüßen
Silphase Technologies
www.silphase.com
Title: Re:Silphase R1 SDR DCC Receiver
Post by: Silphase Tech. on 05. November 2019, 09:44:07
Der maximal darstellbare Bereich auf dem Spektrum - 960kHz
Batterie Li-Pol 12000 mAh.
www.silphase.com
Post by: SP3OSJ on 05. November 2019, 10:02:55
Alexandr show some real photos foto, not a computer foto RX Silphase R1.
The case is from a 3D printer?
Post by: Silphase Tech. on 05. November 2019, 12:28:22
Artur.
Several cases will be produced and will be made of magnesium alloy using a machine tool CNC.
The current case is made using 3D printing and does not have a commercial appearance.
We do not plan to put it on public show, only for partners.
www.silphase.com
Post by: dl2eea on 05. November 2019, 16:01:40
Außer Kosmischem Preis, nichts besonders.
Josef
Post by: Silphase Tech. on 08. November 2019, 08:08:35
Dear Sirs.
Thank you for your messages.
Let us write in English so that everyone can understand our correspondence.
Here are the main points that we have n our products compared to our competitors:
1. QNX Real-time operating system which is used by Boston Dynamics, SAM Electronics and etc.
2. High-quality Graphics in TFT display
3. Magnesium body with magnesium alloy controls, unlike stamped iron and a plastic front panel and buttons.
4. The possibility of an internal upgrade of components while maintaining the user's receiver/transciver body.
5. High-quality sound
6. Waterproof IP55 / IP67
7. Built-in battery 12000mAh or more.
8. There are no cooling fans.
9. Low internal noise receiver.
10. The ability to make up to 10 virtual receivers with the ability to receive 10 frequencies simultaneously (further development of DUAL VFO).
11. 1 optical encoder and 4 mechanical encoders.
In 2020, transceivers will be presented in a similar package with a capacity of 25 and 100 watts.
No one of receivers / transceivers in the global market does not have above mentioned points totally.
The resource of most mass film variable resistors is only 500-1000 rotation cycles. The very high-quality mechanical encoders that we use have over 30,000 cornering cycles.
Therefore, it is not profitable for the component manufacturer to increase the cost of production or increase the resource.
And it is not profitable for the consumer, without sufficient reason, to pay more to the component manufacturer.
We follow a different philosophy when we do not save on components.
No manufacturer in the world provides such a service as we do. Now we use an 16-bit ADC, we actually got a dynamic range of about 130dB, a TFT 800x480 display and a 12000 mAh battery. Suppose, in 3-5 years, manufacturers will release an ADC of 20-24 bits, where you can achieve a dynamic range of 140dB, an OLED display and a battery with a capacity of 18000-20000 mAh. We will change the ADC/DSP board, display board and battery for others, we will get even higher receiver parameters and battery life, and most importantly keep up with the times at that time and at the Top level. The magnesium body will last a very long time. Although it’s not a problem for us to make a body of titanium alloy.
Now we are conducting a dialogue with one of the rescue companies, which became interested in our future 25-watt transceiver and they are asking to make a batch of transceivers in bright orange.
As you can guess these receivers/transceivers can be used in either civil or military areas thank to their QNX Real-time operating system, bodies, batteries and functions.
Best regards
www.silphase.com
