allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: WD8BXS on 15. September 2018, 14:36:14
Title: SOLVED! Version 7 Glitch
Post by: WD8BXS on 15. September 2018, 14:36:14
I am just finishing a Ver 7 build.
MCU will not see USB drive
Good connections to pins 53 and 54, No pin to pin shorts.
Good 5 volts at USB socket.
Bootloader and Firmware upload fine with DFuse
Any Ideas??
Thanks, Chuck
Title: Re:Version 7 Glitch
Post by: DF8OE on 15. September 2018, 14:40:48
Hi Chuck,
the main reason are bad connections from USB plug to MCU or missing / bad 5V. I never have had other reasons for malfunction.
Of course it can be an incompatible USB plug, or it is wrong formatted (no FAT filesystem) or a bad MCU.
Do you have LED on plug which indicates data traffic?
Title: Re:SOLVED! Version 7 Glitch
Post by: WD8BXS on 15. September 2018, 14:42:33
I have to hang my head in embarasment hihi
I put the stupid USB socket on the wrong side of the board HIHI
Chuck ::) ::) ::)
Post by: DF8OE on 15. September 2018, 14:54:03
OK - very good if we can lough about ourselfes 8)...
Working on something sometimes bring "homemade problems" hi hi...
