allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: WD8BXS on 21. December 2018, 18:43:29
Title: SOLVED!! XMIT LED
Post by: WD8BXS on 21. December 2018, 18:43:29
Any ideas what would caused an intermittent XMIT Led on the version 6 McHF??
Thanks,
Chuck
Title: Re:XMIT LED
Post by: WD8BXS on 22. December 2018, 01:40:05
I am not sure.
I do not have it here.
I will find out.
Chuck
Title: Re:XMIT LED
Post by: DB4PLE on 22. December 2018, 11:27:02
Hi Chuck,
it is probably the CW decoder. Last entry in CW menu.
Title: Re:XMIT LED
Post by: WD8BXS on 22. December 2018, 11:42:15
Firmware D2.9.72
Bootloader 4.1.2
I have never noticed that the Xmit LED stopped working if you have the CW decoder turned on .
I will have to experiment with that.
Thanks,
Chuck
Title: Re:XMIT LED
Post by: WD8BXS on 22. December 2018, 11:47:43
I experimented on my radio and yes that will cause the issue.
But my friend just emailed me and it did NOT solve it on his radio.
Still looking for answers.
Chuck
Title: Re:NOT SOLVED!! XMIT LED
Post by: DB4PLE on 22. December 2018, 15:08:14
Hi Chuck,
there is no other code directly accessing the red led in the current firmware except the CW decoder, TX indicator and the VSWR protection (this was not in 2.9.72) . I did not check if we removed code between 2.9.72 and 2.9.89 using the red led.
Please tell/help your friend to upgrade the bootloader and the firmware to the newest version. Due to the "famous" bootloader issue we are not wasting our time to search for strange issues with machines with bootloader versions less than 5.0.x.
And then report if the issue went away.
Post by: WD8BXS on 23. December 2018, 00:49:19
Yes, he installed a newer firmware and all is well. I am helping him get the new bootloader installed.
Thanks for all your help!!
de Chuck WD8BXS
