Title: QEMU und STM32F
Post by: dl8mby on 22. November 2016, 11:52:07
Hallo OM's und vor allem hallo STM32F Experten, Danilo, Ulrich und Co.
Falls nicht schon bekannt, es gibt einen STM32F Emulator.
https://github.com/beckus/qemu_stm32
Diesen habe ich heruntergeladen und Übersetzt.
Hilfreich beim Aufruf waren auch die beiden Seiten:
http://cgi.cs.indiana.edu/~geobrown/stm32/Main/Simulation https://balau82.wordpress.com/2010/11/04/qemu-arm-semihosting/
Leider wird als Maschine z.Z. nur ein stm32-p103 Board von Olimex unterstützt.
Ein Aufruf in der Form:
qemu-system-arm -machine stm32-p103 -kernel mchf.bin -d in_asm,unimp,guest_errors STM32_UART: ADC1 clock is set to 0 Hz. STM32_UART: ADC1 BRR set to 0. STM32_UART: ADC1 Baud is set to 0 bits per sec. STM32_UART: ADC2 clock is set to 0 Hz. STM32_UART: ADC2 BRR set to 0. STM32_UART: ADC2 Baud is set to 0 bits per sec. STM32_UART: ADC3 clock is set to 0 Hz. STM32_UART: ADC3 BRR set to 0. STM32_UART: ADC3 Baud is set to 0 bits per sec. STM32_UART: DAC clock is set to 0 Hz. STM32_UART: DAC BRR set to 0. STM32_UART: DAC Baud is set to 0 bits per sec. STM32_UART: TIM1 clock is set to 0 Hz. STM32_UART: TIM1 BRR set to 0. STM32_UART: TIM1 Baud is set to 0 bits per sec. STM32_UART: TIM1 clock is set to 0 Hz. STM32_UART: TIM1 BRR set to 0. STM32_UART: TIM1 Baud is set to 0 bits per sec. STM32_UART: DAC clock is set to 0 Hz. STM32_UART: DAC BRR set to 0. STM32_UART: DAC Baud is set to 0 bits per sec. STM32_UART: ADC3 clock is set to 0 Hz. STM32_UART: ADC3 BRR set to 0. STM32_UART: ADC3 Baud is set to 0 bits per sec. STM32_UART: ADC2 clock is set to 0 Hz. STM32_UART: ADC2 BRR set to 0. STM32_UART: ADC2 Baud is set to 0 bits per sec. STM32_UART: ADC1 clock is set to 0 Hz. STM32_UART: ADC1 BRR set to 0. STM32_UART: ADC1 Baud is set to 0 bits per sec. LED Off CLKTREE: HSI Output Change (SrcClk:None InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: HSI/2 Output Change (SrcClk:HSI InFreq:8000000 OutFreq:4000000 Mul:1 Div:2 Enabled:1) CLKTREE: SYSCLK Output Change (SrcClk:HSI InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: HCLK Output Change (SrcClk:SYSCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) STM32_RCC: Cortex SYSTICK frequency set to 8000000 Hz (scale set to 125). STM32_RCC: Cortex SYSTICK ext ref frequency set to 1000000 Hz (scale set to 1000). CLKTREE: PCLK1 Output Change (SrcClk:HCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: PCLK2 Output Change (SrcClk:HCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) ---------------- IN: 0x08010768: f861 ee00 str??t lr, [r1]
arm_gic: Set 6 pending cpu 0 arm_gic: Raised pending IRQ 6 (cpu 0) arm_gic: ACK 6 ---------------- IN: 0x08010274: 4621 mov r1, r4 0x08010276: 005a lsls r2, r3, #1 0x08010278: eeb8 0a67 fuitos s0, s15
arm_gic: Set 6 pending cpu 0 ---------------- IN: 0x08010278: eeb8 0a67 fuitos s0, s15
Liefert den o.g. Output.
Mir ist klar, dass die verwendete emulierte HW noch ganz zum mcHF passt, ich wollte aber diese Info hier posten. Vielleicht könnt Ihr damit mehr anfangen und es hilft dem einen oder anderen mehr Einblick in die MC-Seite zu bekommen.
Entsprechend den Anweisungen der schon genannten Seite
Kann man den Gun-Debugger gdb mit bei der Emulation verwenden.
qemu-system-arm -machine stm32-p103 -nographic -monitor null -serial null -semihosting -kernel mchf.elf -gdb tcp::51234 -S STM32_UART: ADC1 clock is set to 0 Hz. STM32_UART: ADC1 BRR set to 0. STM32_UART: ADC1 Baud is set to 0 bits per sec. STM32_UART: ADC2 clock is set to 0 Hz. STM32_UART: ADC2 BRR set to 0. STM32_UART: ADC2 Baud is set to 0 bits per sec. STM32_UART: ADC3 clock is set to 0 Hz. STM32_UART: ADC3 BRR set to 0. STM32_UART: ADC3 Baud is set to 0 bits per sec. STM32_UART: DAC clock is set to 0 Hz. STM32_UART: DAC BRR set to 0. STM32_UART: DAC Baud is set to 0 bits per sec. STM32_UART: TIM1 clock is set to 0 Hz. STM32_UART: TIM1 BRR set to 0. STM32_UART: TIM1 Baud is set to 0 bits per sec. STM32_UART: TIM1 clock is set to 0 Hz. STM32_UART: TIM1 BRR set to 0. STM32_UART: TIM1 Baud is set to 0 bits per sec. STM32_UART: DAC clock is set to 0 Hz. STM32_UART: DAC BRR set to 0. STM32_UART: DAC Baud is set to 0 bits per sec. STM32_UART: ADC3 clock is set to 0 Hz. STM32_UART: ADC3 BRR set to 0. STM32_UART: ADC3 Baud is set to 0 bits per sec. STM32_UART: ADC2 clock is set to 0 Hz. STM32_UART: ADC2 BRR set to 0. STM32_UART: ADC2 Baud is set to 0 bits per sec. STM32_UART: ADC1 clock is set to 0 Hz. STM32_UART: ADC1 BRR set to 0. STM32_UART: ADC1 Baud is set to 0 bits per sec. LED Off CLKTREE: HSI Output Change (SrcClk:None InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: HSI/2 Output Change (SrcClk:HSI InFreq:8000000 OutFreq:4000000 Mul:1 Div:2 Enabled:1) CLKTREE: SYSCLK Output Change (SrcClk:HSI InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: HCLK Output Change (SrcClk:SYSCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) STM32_RCC: Cortex SYSTICK frequency set to 8000000 Hz (scale set to 125). STM32_RCC: Cortex SYSTICK ext ref frequency set to 1000000 Hz (scale set to 1000). CLKTREE: PCLK1 Output Change (SrcClk:HCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) CLKTREE: PCLK2 Output Change (SrcClk:HCLK InFreq:8000000 OutFreq:8000000 Mul:1 Div:1 Enabled:1) arm_gic: Set 6 pending cpu 0 arm_gic: Raised pending IRQ 6 (cpu 0) arm_gic: ACK 6 arm_gic: Set 6 pending cpu 0
Window #2: ==========
arm-none-eabi-gdb mchf.elf GNU gdb (GNU Binutils; home:wkazubski / openSUSE_13.2) 7.10.50.20151217-cvs Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "--host=x86_64-pc-linux-gnu --target=arm-none-eabi". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://bugs.opensuse.org/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from mchf.elf...done. (gdb) target remote localhost:51234 Remote debugging using localhost:51234 0x00000000 in ?? () (gdb) load Loading section .text, size 0x68748 lma 0x8010000 Loading section .ARM.exidx, size 0x8 lma 0x8078748 Loading section .data, size 0x1544 lma 0x8078750 Start address 0x8010000, load size 433300 Transfer rate: 9198 KB/sec, 2015 bytes/write. (gdb) break main Breakpoint 1 at 0x801068e
Hat jemand von Euch eine Ahnung/Idee, wie man das mchf.bin Image durchsteppen könnte (ohne HW Debugger wie den J-Link).
vy73 Markus DL8MBY
Title: Re:QEMU und STM32F
Post by: DF8OE on 22. November 2016, 12:25:57
Hallo Markus,
leider ist das p103-Board zum Testen der Firmware komplett ungeeignet, da es sich um eine ganz andere Hardwarestruktur (incl. Lage / Vorhandensein) diverser Register handelt. Du wirst das so nicht machen können!
Post by: dl8mby on 22. November 2016, 12:41:32
bin jetzt schon ein wenig weiter aber nur ein wenig!
Siehe:
https://www.mikrocontroller.net/topic/412784#4802248
qemu-system-arm -M virt -cpu ? qemu-system-arm -M virt -cpu cortex-m3 -kernel mchf.bin
qemu-system-arm: mach-virt: CPU cortex-m3 not supported
Habe schon einen QEMU version gefunden die F1XX und F2XX unterstützt.
https://github.com/martijnthe/qemu_stm32
Markus |
Post by: DF8OE on 22. November 2016, 13:07:46
Hallo Markus,
auch die F1 und F2 Serie hat eine andere "innere" Hardware mit entsprechend anderen Registerlagen. Einige Register, die die F4 haben, fehlen sogar vollständig. Ich befürchte daher, dass auch das (wenn überhaupt) nur mit sehr viel Handarbeit zum Laufen zu bekommen ist.
Ganz davon abgesehen, dass so viele Hardwareaktionen im mcHF vorhanden sind, dass deren "händische Abarbeitung" (Register setzen bzw. prüfen) sehr aufwändig sein dürfte. Ich würde an deiner Stelle eher versuchen, das live-Debugging mit dem ST-LinkV2 aufzusetzen. Das bringt einen richtig weiter und ist vergleichsweise einfach...
Du kannst das vollständig in Eclipse integrieren - Danilo hat dazu ein ausgezeichnetes How-To geschrieben.
Post by: DB4PLE on 22. November 2016, 16:09:02
Hallo Markus,
der QEMU tut nicht. Wir brauchen einen Cortex M4 mit FPU + STM32F4 Peripherie. Leider noch nicht vorhanden. Habe selbst schon gesucht und habe sogar eine STM32F4 / Cortex M4 Emulation gefunden. Und zwar beim QEMU für ARM: https://gnuarmeclipse.github.io/qemu/
Da gibt es 2 STM32F4 Discoveryboards, die recht ähnlich sind. Auf denen würde mcHF.bin booten, wenn nicht die FPU Emulation fehlen würde. Und damit ist das komplett unbenutzbar mit einem normalen mcHF.bin. Man kann natürlich theoretisch auch eine Übersetzung ohne FPU machen, aber dann unterscheiden sich große Teil der SW und es muss auch der Buildprozess angepasst werden, damit die richtigen Bibliotheken gelinkt werden (z.B. die DSP Lib für Nicht FPU CPUs -> geht vermutlich).
Lange Rede, kurzer Sinn: geht derzeit nicht nach meinem Kenntnisstand.
Und dann fehlt noch die Emulation der Peripherie, zu allererst der Si570.
Post by: dl8mby on 23. November 2016, 08:00:51
Hallo Danilo,
den von Dir genannten Link habe ich auch schon gefunden und versuche das git-package zu compilieren, leider noch mit Fehlern, s.u. (hast Du hierzu eine Idee für die Ursache?)
Andreas hat ja schon mir eingebläut, dass ich mich eher mit dem HW-Debuggen beschäftigen soll, statt Zeit für QEMU zu verlieren.
Da ich aber generell Erfahrung im Umgang mit den STM32F MC's sammeln würde ist aus meiner Sicht die QEMU Emulation durchaus ein nützlicher Helfer, auch wenn er nicht für den mcHF Code taugen sollte.
vy73 Markus DL8MBY
make LINK arm-softmmu/qemu-system-arm /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: warning: libjpeg.so.8, needed by /usr/lib64/libSDL_image.so, may conflict with libjpeg.so.62 monitor.o: In function `hmp_wavcapture': ....mchfTRX/qemu-gnuarmeclipse-dev/monitor.c:1629: undefined reference to `wav_start_capture' hw/char/omap_uart.o: In function `omap_uart_read': ....mchfTRX/qemu-gnuarmeclipse-dev/hw/char/omap_uart.c:77: undefined reference to `omap_badwidth_read8' hw/char/omap_uart.o: In function `omap_uart_write': ....mchfTRX/qemu-gnuarmeclipse-dev/hw/char/omap_uart.c:115: undefined reference to `omap_badwidth_write8' hw/display/omap_dss.o: In function `omap_diss_read': ....
.... ....mchfTRX/qemu-gnuarmeclipse-dev/hw/usb/dev-bluetooth.c:516: undefined reference to `qemu_find_bt_vlan' ....mchfTRX/qemu-gnuarmeclipse-dev/hw/usb/dev-bluetooth.c:516: undefined reference to `bt_new_hci' ../hw/usb/dev-bluetooth.o: In function `usb_bt_init': ....mchfTRX/qemu-gnuarmeclipse-dev/hw/usb/dev-bluetooth.c:533: undefined reference to `hci_init' ....mchfTRX/qemu-gnuarmeclipse-dev/hw/usb/dev-bluetooth.c:535: undefined reference to `qemu_find_bt_vlan' ....mchfTRX/qemu-gnuarmeclipse-dev/hw/usb/dev-bluetooth.c:535: undefined reference to `bt_new_hci' ../ui/vnc.o: In function `audio_add': ....mchfTRX/qemu-gnuarmeclipse-dev/ui/vnc.c:1170: undefined reference to `AUD_add_capture' ../ui/vnc.o: In function `audio_del': ....mchfTRX/qemu-gnuarmeclipse-dev/ui/vnc.c:1179: undefined reference to `AUD_del_capture' collect2: Fehler: ld gab 1 als Ende-Status zurück make[1]: *** [qemu-system-arm] Fehler 1 make: *** [subdir-arm-softmmu] Fehler 2
Eine Installation von libjpeg.so.8 hat auch keinen Erfolg gebracht! |
Post by: DF8OE on 23. November 2016, 13:44:29
Dir fehlen devel-Pakete. Schau doch nochmal nach, welche dev-Pakete als Voraussetzung für das Bauen von qemu aufgeführt sind.
Gibt es in dem Projekt ein configure-Script? Die geben meist richtig transparent Auskunft, wo noch was fehlt...
Die Sache mit den beiden libjpeg-Libs kann auch kritisch sein. Ich denke, es darf nur EINE von beiden installiert sein.
Post by: dl8mby on 23. November 2016, 13:58:51
ich habe das QEMU Packet mit
./configure --disable-werror --enable-debug --target-list="arm-softmmu"
gebaut.
Danach mit ./configure --interp-prefix=arm-softmmu --enable-debug --disable-werror --disable-fdt --disable-libiscsi --disable-libnfs --disable-libusb --disable-usb-redir
Was zwar die Anzahl der Fehler etwas reduziert hat aber der Linkvorgang hat trotzdem nicht geklappt.
Was mich irritiert ist, dass trotz Angabe von --interp-prefix=arm-softmmu
und Ausgabe von configure
-D_GNU_SOURCE=1 -D_REENTRANT -I/usr/include/SDL -lSDL -lpthread -lX11 -D_GNU_SOURCE=1 -D_REENTRANT -I/usr/include/SDL -lSDL -lpthread -lX11 -lSDL_image -lX11 Install prefix /usr/local BIOS directory /usr/local/share/qemu binary directory /usr/local/bin library directory /usr/local/lib module directory /usr/local/lib/qemu libexec directory /usr/local/libexec include directory /usr/local/include config directory /usr/local/etc local state directory /usr/local/var Manual directory /usr/local/share/man ELF interp prefix arm-softmmu Source path /home/markus/Elektrotechnik/Afu/mchfTRX/qemu-gnuarmeclipse-dev C compiler cc Host C compiler cc C++ compiler c++ Objective-C compiler clang ARFLAGS rv CFLAGS -pthread -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -g QEMU_CFLAGS -I/usr/include/pixman-1 -fPIE -DPIE -m64 -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -Wstrict-prototypes -Wredundant-decls -Wall -Wundef -Wwrite-strings -Wmissing-prototypes -fno-strict-aliasing -fno-common -Wendif-labels -Wmissing-include-dirs -Wempty-body -Wnested-externs -Wformat-security -Wformat-y2k -Winit-self -Wignored-qualifiers -Wold-style-declaration -Wold-style-definition -Wtype-limits -fstack-protector-all -I/usr/include/libpng12 LDFLAGS -Wl,--warn-common -Wl,-z,relro -Wl,-z,now -pie -m64 -g make make install install python python -B smbd /usr/sbin/smbd module support no host CPU x86_64 host big endian no target list aarch64-softmmu alpha-softmmu arm-softmmu cris-softmmu gnuarmeclipse-softmmu i386-softmmu lm32-softmmu m68k-softmmu microblazeel-softmmu microblaze-softmmu mips64el-softmmu mips64-softmmu mipsel-softmmu mips-softmmu moxie-softmmu or32-softmmu ppc64-softmmu ppcemb-softmmu ppc-softmmu s390x-softmmu sh4eb-softmmu sh4-softmmu sparc64-softmmu sparc-softmmu tricore-softmmu unicore32-softmmu x86_64-softmmu xtensaeb-softmmu xtensa-softmmu aarch64-linux-user alpha-linux-user armeb-linux-user arm-linux-user cris-linux-user i386-linux-user m68k-linux-user microblazeel-linux-user microblaze-linux-user mips64el-linux-user mips64-linux-user mipsel-linux-user mips-linux-user mipsn32el-linux-user mipsn32-linux-user or32-linux-user ppc64abi32-linux-user ppc64le-linux-user ppc64-linux-user ppc-linux-user s390x-linux-user sh4eb-linux-user sh4-linux-user sparc32plus-linux-user sparc64-linux-user sparc-linux-user tilegx-linux-user unicore32-linux-user x86_64-linux-user tcg debug enabled yes gprof enabled no sparse enabled no strip binaries no profiler no static build no pixman system SDL support yes (1.2.15) GTK support yes (2.24.31) GTK GL support no VTE support no TLS priority NORMAL GNUTLS support no GNUTLS rnd no libgcrypt yes libgcrypt kdf yes nettle no nettle kdf no libtasn1 no curses support yes virgl support no curl support yes mingw32 support no Audio drivers oss Block whitelist (rw) Block whitelist (ro) VirtFS support no VNC support yes VNC SASL support no VNC JPEG support yes VNC PNG support yes xen support no brlapi support no bluez support no Documentation yes PIE yes vde support no netmap support no Linux AIO support yes ATTR/XATTR support yes Install blobs yes KVM support yes RDMA support no TCG interpreter no fdt support yes preadv support yes fdatasync yes madvise yes posix_madvise yes uuid support yes libcap-ng support yes vhost-net support yes vhost-scsi support yes Trace backends log spice support no rbd support no xfsctl support no smartcard support no libusb no usb net redir no OpenGL support no OpenGL dmabufs no libiscsi support no libnfs support no build guest agent yes QGA VSS support no QGA w32 disk info no QGA MSI support no seccomp support no coroutine backend ucontext coroutine pool yes GlusterFS support no Archipelago support no gcov gcov gcov enabled no TPM support yes libssh2 support no TPM passthrough yes QOM debugging yes vhdx yes lzo support no snappy support no bzip2 support yes NUMA host support no tcmalloc support no jemalloc support no avx2 optimization yes
make auch andere Targets compiliert:
z.B. CC disas/cris.o CC disas/i386.o CC disas/m68k.o CC disas/microblaze.o CC disas/mips.o CC disas/moxie.o CC disas/ppc.o CC disas/s390.o CC disas/sh4.o CC disas/sparc.o CC disas/lm32.o
Markus
Post by: DF8OE on 23. November 2016, 14:06:24
Schau mal hier (http://stackoverflow.com/questions/26664946/target-list-meaning-in-qemu-installation)
