allgemeine Kategorie => UHSDR Firmware => Message started by: qrper on 08. May 2018, 07:57:31
Title: sparrow psk tx
Post by: qrper on 08. May 2018, 07:57:31
hi all,
I have the Sparrow version of the radio and want to work in digital modes tx and rx
what is the procedure to accomplish this do I need an external modem etc or can it be done just using the usb connection
regards gm6jua
Title: Re:sparrow psk tx
Post by: DF8OE on 08. May 2018, 08:11:08
Firmware is capable to work in PSK and RTTY "standalone". If you want to do it via software (PC/laptop) you only need an USB connection. Firmware serves CAT and USB audio simultaneously via one USB connection.
Post by: qrper on 08. May 2018, 12:57:11
Quote from: DF8OE on 08. May 2018, 08:11:08
many thanks Andreas,
I have hooked it up to my computer selected bpsk-U and am using ham radio deluxe on the computer but cannot get the radio to go into tx/rx should I set the rit button to show dig ext sorry for the daft questions but new to sdr qrp and usually use a kenwood ts590 sg in the shack
but I have no setup instructions for how to do this for the sparrow
73's dave gm6jua
Post by: DF8OE on 08. May 2018, 18:06:15
Your program should use CAT commands for RX/TX switching and frequency control.
I am only working with Linux and all my programs use CAT...
