allgemeine Kategorie => UHSDR Firmware => Message started by: SP3OSJ on 22. September 2018, 16:42:09
Title: FreeDV frequency RX/TX
Post by: SP3OSJ on 22. September 2018, 16:42:09
Hi
Title: Re:FreeDV frequency RX/TX
Post by: DB4PLE on 22. September 2018, 18:00:12
Hi Artur,
Frequency does not change DURING transmission, it transmits obviously on the wrong frequency when using FreeDV.
Nevertheless, this should not happen. Which firmware version have you been using? And the displayed frequency is strange, do you have configured transverter settings? If so, please try without transverter settings active. If not, then where do these settings come from?
Post by: DF8OE on 23. September 2018, 07:50:28
I have just verified on 40m: freeDV TX and RX frequencies are working as expected. This must be related to transverter settings. I never have had used these settings and cannot tell if they are working or not.
Post by: peter_77 on 23. September 2018, 10:46:55
Guess he is using his own 23cm RF frontend with the UI Board:
https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1094;start=15 (https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1094;start=15)
Post by: DB4PLE on 23. September 2018, 13:46:46
Hi Artur,
well, since it works for us, without full information about your setup and the steps how to reproduce the issue on a stock (!) OVI40 or mcHF you are out of luck most likely. Please provide complete information about your setup (hardware and software) and we may be able to help. At least I won't touch this issue at all before more information is provided.
Post by: DB4PLE on 23. September 2018, 19:25:50
Hi Artur,
you still did not tell us which firmware you are using and hardware you are using.
I already checked, and the transverter settings just change the displayed frequency value, these are not used in the actual tuning of the oscillator. So there is no influence here.
However, FreeDV does ZeroIF transmits (i.e. it does not do a frequency shift of -6 khz during TX as it does during RX. Which means, it changes the tuning of the Si570 by 6khz compared to the RX Si570 frequency in order to transmit at the same spot it receives.
So if you use your own hardware (which you are obviously using, which is not a problem for me; however, what is a problem for me is that you do this without telling us rightaway and, frankly said, wasting our time by this) does some kind of multiplication of the Si570 output frequency, well, that's it. Your transmission will be offset by (Multiplier-1)x xlate_frequency. You can do the math on your own.
