allgemeine Kategorie => UHSDR Firmware => Message started by: DL8EBD on 15. April 2020, 05:17:36
Title: display frequencies up to 99 GHz
Post by: DL8EBD on 15. April 2020, 05:17:36
Title: Re:display frequencies up to 99 GHz
Post by: Michael_K on 15. April 2020, 08:49:19
Danke Thomas,
kommt mir sehr zu passe. Für die Nutzung des TRV von Artur
gesunde vy 73 aus Erfurt
Post by: SP3OSJ on 15. April 2020, 09:56:19
Hi
It is now fully integrated with TRV on QO 100.
All day, Danilo
Artur
Post by: SP3OSJ on 16. April 2020, 11:49:02
Hi Thomas
This can be set from the keyboard.
Press LCD wherever there is frequency
Then "Frequerncy Set"
Artur
Post by: SP9BSL on 16. April 2020, 12:01:39
Quote from: SP3OSJ on 16. April 2020, 11:49:02
Not sure about this, the virtual keyboard frequency variable is only 32bit (the value must be <2^32, so below the ~4GHz) :https://github.com/df8oe/UHSDR/blob/4ecbff8b626662af6c7300e92830199ee001ab5b/mchf-eclipse/drivers/ui/ui_vkeybrd.c#L545 (https://github.com/df8oe/UHSDR/blob/4ecbff8b626662af6c7300e92830199ee001ab5b/mchf-eclipse/drivers/ui/ui_vkeybrd.c#L545)
although may be wrong, not have here the rig to check this.
Post by: DB4PLE on 16. April 2020, 20:26:14
I did not check yet in the code, but the frequency entered using the touch screen is almost 100% sure the "real" TRX frequency, i.e. the frequency without the offset. So there is no immediate need to fix this as long as we keep it this way.
Otherwise we would have to teach the touchscreen input the difference between transverter and non-transverter operation.
Post by: SP9BSL on 17. April 2020, 06:07:29
Quote from: DL8EBD on 16. April 2020, 18:50:36
@Sławek
I have noticed that artifacts are created when entering a frequency - should I open an issue for it?
Hi Thomas,
yes, you may create the issue regarding artifacts. I'm deep in hardware now, no time to fix this in firmware. As Danilo said not urgent need to fix the transverter mode. The artifacts are caused by not proper dot size handling, will fix this imediately when go back to the firmware. There will be a lot changes in this area regarding my hardware and new functionalities of virtual keypads - my private lib has evolved since the one implemented in our UHSDR...
Post by: OE1FHB on 17. April 2020, 06:31:12
Guten Morgen Thomas !
Suche krampfhaft im Wiki Anleitung zum aktivieren des zusatz
Touchpanels zur Frequenzeinstellung .
Bin aber nicht fündig geworden .
Bitte könntest du Hinweis geben wie man das aktiviert .
Danke im voraus.
vy 73 OE1FHB
Friedrich
Post by: DF8OE on 17. April 2020, 06:35:11
Einfach auf die Frequenzanzeige tippen und dann "Frequency Set" wählen... War intuitiv. Gleich der erste Versuch führte zum Erfolg ;D
Post by: OE1FHB on 17. April 2020, 06:40:54
Danke für die promte Antwort , aber bei mir öffnet das nur
ein Touchfeld zur Band Auswahl .
FW.:2.11.81
BL.:5.0.3
#Vy73 OE1FHB
Friedrich
Post by: SP9BSL on 17. April 2020, 06:45:06
Friedrich,
this is only for 3.5" or more display (480x320), there is no possibility to show the keypad on usual mcHF display - not enough space for graphics.
My fault- not proper info for 480x320 display in wiki. I must add the screenshoot feature first to make easier the wiki expanding.
Post by: OE1FHB on 17. April 2020, 06:49:15
Danke Slawek , das ist das Problem !
Vy73 OE1FHB
Friedrich
Post by: SP9BSL on 17. April 2020, 06:56:31
Thomas, in fact I have the 3.5" display in both mcHF and OV I40 UI too, almost forgot abut the initial mcHF display :)
Anyway, the short info is in this thread (7th answer):
https://www.amateurfunk-sulingen.de/forum/index.php?board=19;action=display;threadid=1072 (https://www.amateurfunk-sulingen.de/forum/index.php?board=19;action=display;threadid=1072)
Post by: DF8OE on 17. April 2020, 07:07:51
So here. A soon as the 3.5" appears I have modified all my mcHF and OVI40 for usage of the higher resolution LCDs. If I get a device for repair which has the 320x240 I feel like beaming in the stone age ;D... But for all the owners of a clone which has poor housing so that you cannot add bigger LCD we should publish a comparison of "what does not work with small LCD". E.g. "full size WF / scope" for example. And I think no developer is working on new features for the small LCD - everything that will be added is for higher resolutions...
Post by: SP9BSL on 17. April 2020, 08:29:13
yes, for the current point of view on level of development stage the 320x240 display looks like a little "oldschool" type, but when I recall the first look at the project Chris shown us, I was very enthusiastic and thought this will be enough, this was a good job by Chris&co over 7 years ago, plenty clones still selling today. But... if someone stays at certain stage he really steps back. We are moving forward with development of UHSDR sometimes faster, sometimes slower but still having a lot of ideas. I hope the old display will not make the life harder too much for developers like the 8086 was a kind of obstruction for later chips from Intel... So, if one may move to the bigger screen in mcHF, well... it is highly recommended!
Post by: DB4PLE on 17. April 2020, 11:15:04
I think, not offering some capabilities on a too small screen is not a big issue technically, keeping track of different capabilities or ways of working in documentation and communication is the bigger issue here.
For the specific discussion point, I think it would be doable to offer the frequency input also on the smaller display. The amount of requests we get for this capability is low (read zero so far). So unless someone does it or huge demand sparks, we just should document the difference (which is a good point for moving to a larger display if possible.
