allgemeine Kategorie => UHSDR Firmware => Message started by: satoryboy on 04. July 2020, 11:17:31
Title: Mod-fw of UHSDR 2.11.87m4
Post by: satoryboy on 04. July 2020, 11:17:31
Hi All
I’m publishing a new version of my mod firmware. Added "on-the-fly" transmission power adjustment. In the transmission / tuning mode, make by the M1 button the active box PWR and adjust the power with the first encoder. At the selected FULL power, the value of the band adjustment of the FULL power is changed, otherwise the adjustment is 5W. Make sure that the FULL adjustment is not less than 5W. A long press of the G3 button (PA) sets the power setting to FULL. 73!
Fw: https://yadi.sk/d/MIK3wz7GxUQ1hw
Source: https://yadi.sk/d/OjU8DDWUGckrog
Title: Re:Mod-fw of UHSDR 2.11.87m4
Post by: satoryboy on 11. July 2020, 04:02:39
Learned to compile compact firmware under Ubuntu - the volume is about 370 kB:
https://yadi.sk/d/QMCBIJXkMG7nDw
