Title: Mod-fw of UHSDR 2.11.88m2
Post by: satoryboy on 23. July 2020, 15:01:15
Hi All
I'm posting the next version of my mod firmware from UHSDR - 2.11.88m2. An alternative adaptive noise reduction (Leaky LMS algorithm) has been added to the interface. I named it ANR. He already worked once in this firmware, is present in the source code, but was undeservedly dismissed. Differs in the absence of sound artifacts, which very quickly get tired when working on the air. 73!
Firmware: https://yadi.sk/d/4UT5yHPl00R9MA
Sources: https://yadi.sk/d/LNPWDh2yQKk9cw |
Title: Re:Mod-fw of UHSDR 2.11.88m2
Post by: DF8OE on 23. July 2020, 16:22:37
...but does not suppress noise as the one which substitutes the one you introduced again :o.
Post by: satoryboy on 23. July 2020, 16:27:16
Does not replace, you can turn on any one you want. They complement each other perfectly, each has its own strengths. Thank you for your attention. |
