Title: I2C speed in F7
Post by: Co on 19. August 2020, 09:43:12
Hello,
Is the i2c speed in the F7 still adjustable via a menu option ?
Regards Co |
Title: Re:I2C speed in F7
Post by: DF8OE on 19. August 2020, 10:05:39
Hi Co,
no, its fixed.
Post by: Co on 19. August 2020, 14:24:46
Hello Andreas,
I'm trying to bring a OVI40 V1.7 board back to live again. Its runs stand alone 5V on pin 28. It boots but get the WM8731 error message at boot up. The I2C connections seem to be OK. I do however measure 2.5 volts on pin 27 P1 (UI-3V soft)is floating (RF board is not connected). So worst case : I've blown up the codecs one way or the other. ??? :'( . Could you think of something else.
Regards
Co |
Post by: DF8OE on 19. August 2020, 14:58:34
Hi Co,
first you need to test if analog & digital 3.3V supply for the codecs is present (on BOTH codecs). Second you have to test if SDA and SCL from both codecs are connected to the correspondent MCU pin and nothing else Third you an chekc for bad solderings at codecs.
For testing you can connect a scope to SDA and SCL and check if there is "life" when powering up UI PCB for a small time. Amplitude must reach 0V/3.3V.
Good luck - feedback if you have fixed it is welcome :D!
vy 73 - stay healthy Andreas |
