Title: Mod-fw of UHSDR 2.12.0m2
Post by: satoryboy on 27. April 2021, 18:33:10
I'm posting a new version of the mod-firmware based on the stock from UHSDR - 2.12.0m2. In addition to fixing minor non-critical errors, all improvements concern the interface with a resolution of 480x320, that is, for devices with UI OVI40 and Sparrow. Therefore, the archive contains releases only for them. The interface is almost the same as in TRX Amber versions 3.5 and 4.0 ". The F6 button is still not used in the stock firmware, so we left the F-menu as it is. Hope you like it. 73!
Firmware - https://disk.yandex.ru/d/vTnwTNOn3pVQ6A (https://disk.yandex.ru/d/vTnwTNOn3pVQ6A)
Sources - https://disk.yandex.ru/d/4MhupAXGbPbf8g (https://disk.yandex.ru/d/4MhupAXGbPbf8g)
Title: Re:Mod-fw of UHSDR 2.12.0m2
Post by: arcticsilver on 27. April 2021, 19:33:36
how did you get display like that? |
Post by: satoryboy on 27. April 2021, 20:13:35
Sent by a good person. The display is purely technological, a piece of paper instead of reflective film. I can't find compatible models on sale now. |
