ovi40_displaybuild [14.01.2018 17:11] – df9ts | ovi40build:ovi40_displaybuild [17.01.2018 10:56] – [Displayboard auf UI Board befestigen] df9ts_user | ||
- | Quelle: https:// | ||
+ | Sobald | ||
+ | [{{:projekte: | ||
Zeile 10: | Zeile 43: | ||
+ | Weil der " | ||
+ | and screw it to lcd with PEM FH flat bolt like this (more " |
