ovi40_displaybuild [14.01.2018 18:06] – df9ts | ovi40_displaybuild [14.01.2018 23:07] – df9ts | ||
Quelle: [[https:// | Quelle: [[https:// | ||
- | Für die Bestückung | + | ==== Display |
Zeile 12: | Zeile 17: | ||
- | {{:projekte:ovi40-sdr:lcd_35_40pin_df8oe_sp9bsl.pdf|lcd_35_40pin_df8oe_sp9bsl.pdf}} | + | ==== Display Helligkeit ==== |
+ | DL8EBD: auf Anraten vom Andreas sind es jetzt 10R geworden.... | ||
+ | Jetzt habe ich 60mA | ||
+ | I have take a look at the datasheet. It tells 60mA is maximum for time > 1 min. for time < 1 min 75mA is the highest rate. | ||
+ | ==== Bestückung ==== | ||
+ | Weil der " | ||
- | \\ | + | ==== Disconnecting SDO Line ==== |
+ | yes - your shipment was before 05/01/2018. You got the ones with SDO connected. | ||
+ | And it is only connection between LCD FPC connector SDO and pin12 / SDO. | ||
+ | If pin12 is no longer connected to FPC but it is still connected to pin headers everything is done. | ||
+ | (14Jan18 23:49) |
