ovi40_displaybuild [14.01.2018 18:10] – df9ts | ovi40_displaybuild [15.01.2018 15:30] – df9ts | ||
- | Quelle: [[https:// | + | ==== Display Platine ==== |
+ | * 3.5" Display (OVI40 Standard) | ||
+ | * 3.2" Display (während des UI Betatests benutzt) | ||
+ | * 2.5" Display (mcHF Standard) | ||
Zeile 14: | Zeile 37: | ||
+ | Weil der " | ||
+ | (15Jan18 11:00) |
