ovi40_displaybuild [14.01.2018 18:10] – df9ts | ovi40_displaybuild [16.01.2018 11:35] – df9ts | ||
+ | ==== Display Kalibrierung ==== | ||
Zeile 14: | Zeile 43: | ||
+ | Weil der " | ||
+ | (15Jan18 11:00) |
