ovi40_displaybuild [14.01.2018 18:11] – df9ts | ovi40_displaybuild [16.01.2018 11:35] – [Display Kalibrierung] df9ts | ||
- | Quelle: [[https:// | + | ==== Display Kalibrierung - wichtig!==== |
Zeile 14: | Zeile 43: | ||
+ | Weil der " | ||
+ | (15Jan18 11:00) |
