ovi40_displaybuild [14.01.2018 22:49] – df9ts | ovi40build:displaybuild [17.01.2018 12:46] – df9ts_user | ||
- | Quelle: [[https:// | + | ==== Display Kalibrierung - wichtig!==== |
Zeile 14: | Zeile 43: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 43: | Zeile 63: | ||
Weil der " | Weil der " | ||
- | I think I got LCD's with the SDO line still connected as there is no cutting visible | + | < |
+ | 1. Use a plastic hex shape spacer | ||
+ | by putting | ||
- | (14Jan18 23:49) |
