ovi40_displaybuild [14.01.2018 23:06] – df9ts | ovi40_displaybuild [15.01.2018 10:16] – [Display Bestückung] df9ts | ||
- | Quelle: [[https:// | + | ==== Display Helligkeit ==== |
Zeile 16: | Zeile 29: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 45: | Zeile 49: | ||
Weil der " | Weil der " | ||
- | ==== Disconnecting SDO Line ==== | ||
- | I think I got LCD's with the SDO line still connected as there is no cutting visible and there is connection between SPI SDO (J106-14) and TP SDO (IC102-12). | ||
