ovi40_displaybuild [14.01.2018 23:06] – df9ts | ovi40build:displaybuild [17.01.2018 12:47] – [Display Platine] df9ts_user | ||
+ | | 95% 50% 50% | | ||
- | Quelle: [[https:// | + | ==== Display Kalibrierung - wichtig!==== |
Zeile 16: | Zeile 44: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 45: | Zeile 64: | ||
Weil der " | Weil der " | ||
- | I think I got LCD's with the SDO line still connected as there is no cutting visible | + | < |
+ | 1. Use a plastic hex shape spacer | ||
+ | by putting | ||
- | (14Jan18 23:49) |
