ovi40_displaybuild [14.01.2018 23:07] – df9ts | ovi40_displaybuild [16.01.2018 10:30] – df9ts | ||
- | Quelle: [[https:// | + | ==== Display Kalibrierung ==== |
Zeile 17: | Zeile 40: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 46: | Zeile 60: | ||
Weil der " | Weil der " | ||
- | ==== Disconnecting SDO Line ==== | ||
- | I think I got LCD's with the SDO line still connected as there is no cutting visible and there is connection between SPI SDO (J106-14) and TP SDO (IC102-12). | ||
