ovi40_displaybuild [14.01.2018 23:07] – df9ts | ovi40build:ovi40_displaybuild [17.01.2018 08:17] – df9ts | ||
- | Quelle: [[https:// | + | ==== Display Kalibrierung - wichtig!==== |
Zeile 17: | Zeile 43: | ||
- | Jetzt habe ich 60mA | ||
- | ==== Bestückung ==== | ||
Zeile 46: | Zeile 63: | ||
Weil der " | Weil der " | ||
+ | Als temporäre Lösung | ||
- | yes - your shipment was before 05/01/2018. You got the ones with SDO connected. | + | ==== Schnittstelle |
- | And it is only connection between | + | Zur Information: |
- | If pin12 is no longer connected to FPC but it is still connected to pin headers everything is done. | + | [{{: |
- | (14Jan18 23:49) |
